Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 92
Thread: White ring on water tile
    May 2015
    Fullerton, CA
    642
    Had to drop my water level a little, the is a bit of a white ring at the old level, 32 day old water. I tried a nylon brush it helped but i can still see it. What can i do to remove it without harming the tille?
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Re: White ring on water tile
    Dilute acid 4:1 in a spray bottle and go at it. If that's not strong enough then go 50/50.
    Why lower the water? Be cautious of the skimmer suction if you go too low. At higher pump speeds you might start sucking air.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2015
    Fullerton, CA
    642
    Take a look at my thread on skimmer level. I think it was too high, the water was hitting the tab i. The middle top of the skimmer mouth. Let me know if you think it was too high?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,748
    Are you monitoring your CSI? Need to keep the CSI between -0.3 and 0 to avoid scale. More here, Pool School - Calcium Scaling
    May 2015
    Fullerton, CA
    642
    Tried 4:1, helped, then 3;1, then 2:1.
    Well tile dried, ring still there. Thoughts?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Yep. That's why the CSI is so important. Too high and you get scale and deposits, too low and you'll leach calcium out of your plaster.
    -Brian-
    POOL BUILD
    May 2015
    Fullerton, CA
    642
    Is there a test for CSI? CH is 275.
    Ok, added my numbers to Pool math, csi is showing .05.
    Here is what i am dealing with afterwards.
    Thoughts?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    Lower the pH to 7.2.
    The main thing that's bumping up the CSI is your alkalinity. Calcium has a surprisingly small effect on it. My scale CH is 900 ppm and i have no scale.
    -Brian-
    POOL BUILD
    May 2015
    Fullerton, CA
    642
    Drop it to 7.2 and keep it there? I was dropping it to 7.2?and letting drift to 7.8. So now i should just keep it at 7.2.
    How do i get the ring off the tile?
    DFW, TX
    24,748
    Yes, keep CSI between -0.3 and 0. The ring around the pool will go away on its own. Mine did. I scrubbed it a bit with a nylon brush sometimes to help it along. You can lower CSI to -0.6 to help it dissolve faster.
    Managing your CSI will add a decade or more to the life of your plaster. Tweak PH and TA to move the number.
    May 2015
    Fullerton, CA
    642
    Ok confused now. So now i need to keep ph @7.2. And the ring will go away?? Is there somthing i can use toremove it so i dont have to look at it?
    Pool math is not really good for figuring this out.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    From you other thread - Go ahead and lower to 7.2 now. there is no reason to wait until 7.8 to lower it back down. PH rise is exponentially faster at low pH levels so to be most effective in lowering your TA, lower the pH to 7.2 and add acid once the pH gets to 7.4-7.5. Repeat the process until the TA gets to where you'd like it, then let the pH settle in around 7.6-7.8.
    Acid will remove the ring. Put strait acid in the spray bottle if you want and use stiff brush. It will come right off.
    -Brian-
    POOL BUILD
    May 2015
    Fullerton, CA
    642
    Here are my numbers in pool math notice CSI? Is that number bad?
    Strait acid will not harm the tile grout?
    Ok, i thought you guys wanted me to let ph drift back to 7.8. I will drop it back to 7.2 tomorrow. What TA am i shooting for?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    TA 60-70.
    I consider a CSI of 0 to -0.3 ideal. Aim for that range. To lower the TA you might end up with a temporary CSI that is very negative but that is unavoidable and will not cause damage because it is short-term.
    The acid will dissolve some of the grout but if you want the ring gone, the only other option is a pumice stone or a calcium eraser.
    Far easier than any of that is to prevent it from forming in the first place.
    -Brian-
    POOL BUILD
    DFW, TX
    24,748
    No, it is not bad. But, your water has tendency to scale and the CSI is going to go up. Slightly negative is better. -0.3 to 0 is preferred. It is best to move it to -0.3 and let it rise back to 0.
    60 is probably a good TA for your pool. Every pool is different. You will know more as it gets there and your pH rises less.
    May 2015
    Fullerton, CA
    642
    Quote Originally Posted by bdavis466 View Post
    TA 60-70.
    Pumiice stone or calcium eraser? Will those scratch the tile? I do want to remove the ring but dont want to disolve grout or scratch tile to do it. These has to be a not damaging way to do this.
    I would have avoided it if i was aware it was a problem, nobody mentioned CSI before today.
    DFW, TX
    24,748
    I gave some suggestions on removal in post 10.
    May 2015
    Fullerton, CA
    642
    Well i just tested TA, its at 70! had not tested it since 8/17. I started dropping PH to 7.2 on Monday, I did not think it would drop TA this fast. Ran the test 3 times to confirm. So my CSI at 7.4ph is -0.34. Dropping PH to 7.2 gives me a csi of -0.53. I will keep lowering ph to 7.2 until TA drops to 60 giving a CSI of 0.3 to -0.32. This will allow PH to run at 7.5. Will try a calcium eraser tomorrow. If that does not work I will be raising the water level back up. Need a sticky on new pool owner thread to get TA down to 60-70, nobody mentioned 110-120 would creAte a scaling issue.
    I cant imagine how people who are not on this forum dont have major issues with there pool, i am having a hard time and i am buried in this forum.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    That's what the recommended levels are for. People with no experience or prior knowledge can test their water, read up on adjusting their levels and shoot for the recommended numbers for their type of pool.
    The only reason you knew their was an issue was because you dropped the water level. Had you not done that and lowered the TA as earlier advised, the deposits would have redissolved into the water and the tile would have been as clean as the day you filled the pool.
    When water evaporates it leaves everything in it behind (calcium, salt, etc). Regardless of your water chemistry, once the water evaporates and the area dries there will be some solids left over.
    -Brian-
    POOL BUILD
  20. Back To Top    #20
    May 2015
    Fullerton, CA
    642
    Yep, not blaming anyone, its my fault, was just more focused on all the other thing tests, etc, etc. Perhaps i will just raise the water level again rather than trying to mess with removing the ring. Will pick up a calcium eraser tomorrow and test it out. If that does not work i am raising the water level and will let the correct chemisty remove the ring.
