Thread: Leaking Heater
    KatyTXPoolOwner's Avatar
    Jul 2015
    Katy TX
    90
    Leaking Heater
    Our heater has been leaking since it was put in. 2 years ago. PB couldn't get it to stop, neither could Pentair guy. See the wet spot on the concrete. Any thoughts?
    23,000 gallon gunite chlorine pool / spa .. French Gray Pebble Sheen .. IntelliFlo VF main pump .. IntelliFlo VS spa booster pump .. WhisperFlo 1HP water feature pump .. LA01N .75HP cleaner booster pump .. Letro Legend Platinum cleaner .. Quad DE 100 filter .. Max-E-Therm 400k heater .. Rainbow 320 chlorinator .. 1.5HP blower .. Easy Touch 8 remote control .. 8 Twirlybyrd jet spa .. Paralevel .. TF-100 w/SpeedStir
    Jun 2016
    Oklahoma City, OK
    49
    Re: Leaking Heater
    Looks like it's leaking from that small drain plug on the bottom based on calcium(white) buildup. Most likely needs a new oring
    Jun 2016
    Oklahoma City, OK
    49
    Re: Leaking Heater
    Or apply silicone paste tape to the threading of the plug
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Re: Leaking Heater
    or some teflon tape to the threads
    Dolphin E10 Cleaning Robot.
    Jul 2015
    Katy TX
    90
    Re: Leaking Heater
    I don't know everything they (PB and Pentair tech) did but do know they tried Teflon tape, more Teflon tape, and even replaced the plug and o ring.
    Jun 2016
    Oklahoma City, OK
    49
    Re: Leaking Heater
    Make a ball out of Teflon tape and stuff the hole with it
