Thread: Hello...I'm a newbie and I have a question
    MDrechsel's Avatar
    Aug 2016
    Apopka, Florida
    1
    Hello...my name is Mari, that's Marie with no E, I am a Florida Native, wife to a wonderful husband, mother to two amazing kids, and the proud owner of a 22ft, steel frame, above ground pool. My husband and I were wanting to sink the bottom of the pool, roughly 1.5 -2 inches in the ground, but we are not sure if we should or not. Any advice or suggestions would be great! Thanks in advance!
    Mari Drechsel
    22ft Above ground
    Steel Frame
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Hello...I'm a newbie and I have a question
    Welcome, I would suggest asking this question in the aboveground pool section as you will likely get more on topic views there
    Ike
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Why would you got through that much trouble for 2 inches?
    Jun 2016
    Panama City
    100
    I too live in Fl! I have seen wash out numerous times from a downpour. Your 2" could become 4or 5 quickly! Just a thoughtful observance. Mine sits directly on the ground even though it's exactly 2" out of level. It was a quick and dirty install. We need more info! Thanks Jec
    May 2012
    Montville NJ
    545
    Short answer - yes
    Long answer - When you bury an above ground pool (with a few exceptions) it can cause problems. The weight of the earth pushing in can cause the walls to collapse if you ever drain your pool, such as when you put a new liner in. In addition, burying a pool can cause it to corrode faster. When you bury most pools, it also voids the warranty. Now some pools can be buried, they are stronger, and have either a coating or are not made of metal. Having said that, many people have successfuly buried their above ground pools. Now, you said you want to bury it 2 inches. That is not going to cause a collapsing problem,, and unless your soils is allways saturated to the top, it should not be much more a corrosion issue thatn mormally occurs when dirt collects next to a pool. Maybe it will void your warranty, if that matters to you. But, as someone else said, why 2 inches? That is a lot of work and effor, not no real benefit - unless you are trying to match it to an existing deck. I have a 48" pool, and if it ever dies, I plan on getting a 52" and dropping it 4" so it lines up with my current deck.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
