Thread: Question Regarding CYA
    Aug 2016
    HICKSVILLE, NY
    87
    I've had this pool for 15 years, but this is the first year that I've been closely monitoring the chemistry (just spent 3500 on a new heater). CYA has been steadily inching up to 120. After downloading the Pool Calculator and plugging in today's readings, I realized that with CYA at 120, the amount of FCL required to properly sanitize the water goes up to the 9-15 range. I had been maintaining it between 3 and 5. Am I understanding this correctly?
    28,000 gallons, 18x36, vinyl liner
    Hayward C4030 Cartridge Filter, Hayward TriStar VS 900 Pump, Raypak 400 BTU gas heater,
    Stenner 45mhp10 Peristaltic Pump (for bleach injection)
    2 skimmers, 2 returns, main drain, Lamotte ColorQ and TF-100 test kits
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,563
    Re: Question Regarding CYA
    Tom,
    Here is a chart showing the relationship.. Chlorine CYA Chart
    The chart only goes up to a CYA of 100, so your 9 to 15 FC level sounds about right. I suggest you replace enough water to get your CYA in the 40 ppm range. Might have to do that is stages so you don't have to drain too much at once.
    With an FC of 10 your pH testing will be inaccurate.
    Aug 2016
    HICKSVILLE, NY
    87
    Agreed. I drained 13 inches to start. By my calculations, that's about 5300 gallons, or about 19% of the pool. That should bring me just below 100 CYA....hopefully. Thanx.
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Tomolena- how do you sanitize your pool? Are you using products which continually keep adding more CYA to your water, like pucks or powder?
    Yip
