Results 1 to 10 of 10
Thread: Filter Issues - How do you know if your filter is really working?
    May 2015
    Burbank, California
    66
    We have a 20 year old filter.
    It looks very close to this filter. (Pentair 2000??) The labels have faded away, so I don't have any idea.
    Everyday or Every other day, after I started managing the pool, i've been sweeping the pool floor to the deep end. The floor of the pool always has a thin layer of dirt? After doing that, I manually vacuum the pool. But after a couple of days, there is again a thin layer of dirt at the pool floor.
    Is this is normal? How often do people normally have to vacuum the pool floor?
    I know some people have automatic cleaners, but i'm just doing it manually.
    During this entire processes. I'm in the middle of an epic yellow algae fight and i'm not really sure if i'm winning the battle or not. My current FC is around 12-14 ppm. I want to shock the pool, but i'm not sure if the filter will be able to actually filter the pool or not.
    I brought out our pool man and when he came out like 2 months ago, he said the filter is fine, but he thinks the sand? or whatever is in the filter that cleans the water is leaking back into the pool. Today he came out and told me I need to replace the filter without really checking the pool. I'm not sure what he would even check, but he even claimed that he personally doesn't know how to replace filters. And gave me a number of someone else that does.
    I'm tackling alot of pool issue all at once, and all these things are going to be really pointless if my pool filter isn't really doing it's job. Right?
    Any suggestions? How do I know if my pool filter is actually working? What are the signs I should be looking for?
    Can I shock my pool even if my pool filter is "kind of" working? Or should I address this issue first
    23,000 Gallons Plaster Pool & Spa (1989). Hayward Super II 1.5 HP Pool Pump (Single Speed). Cartridge filter. Kit Tester: Taylor K-2006.
    Jul 2014
    Hope Mills, NC
    565
    Re: Filter Issues - How do you know if your filter is really working?
    90% of all filter problems are actually chemistry problems. You need to get all of the algae in your water and in your filter killed. After the algae is dead and falls to the floor of your pool, and you vacuum and backwash, if the problem still exists, you can work on the filter.
    P.S. Just to be first, we will need real test results, preferably from a TF 100 (or the Taylor K2006) test kit. And...We Never Shock!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    30,287
    As above, we cannot guess at your pools condition....we need test results to give us some reliable data.
    That said, the "dirt" you say continually reappearing on your pool floor is dead algae.
    I don't think you have multiple issues......I think you have a misunderstanding of what you are seeing and I am positive you are not testing properly so that you can manage your pool or so that we can help.
    At some point, you will need to bite the bullet and get one of the two suggested kits here on the forum. That will lead you to a whole new understanding of your pool chemistry. Keep reading the forum and about the thousands of people that have made the commitment to learn how to manage their pools.
    Feb 2015
    Chandler AZ
    770
    Also, maybe post pictures of your actual filter and other equipment. Quite possibly, someone here can identify it and help you better understand exactly what it all is and how to use/maintain it better.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    May 2015
    Burbank, California
    66
    Build up at bottom of the pool - Pictures
    My readings (T-2006)
    FC - 12.5
    pH - 7.4
    TA - 180-200
    CH - 750
    CYA - 80-90
    I have been testing twice a day.
    Sorry, I think all the comments are under the assumption i have not been testing. But I have been. I just didn't mention it in my original post.
    Ok let me do that right now.
    30,287
    Having two threads is a killer. It is so hard for us frequent responders to follow your progress. We get confused and skip over you. Keep all you post under this thread.
    May 2015
    Burbank, California
    66
    Right, I just don't want to get in trouble for posting things where they shouldn't be. Not sure how strict you guys are, and i'm pretty new to the forums.
    30,287
    Just keep things together so your "story" is in one place and all will be fine.
    May 2015
    Burbank, California
    66
    I ended up just getting yellowtrine to help fight off the algae. $29.99 at my local pool store, but I was worried this algae was becoming resistant to the current levels of chlorine.
    I just wanted to get the whole thing over with.
    I already had my pool at around 20 ppm FC. And threw in 1 lb of shock into the skimmer to make sure it got the job done.
    I used around half the yellowtrine while adding a gallon of chlorine mirroring where I used the powder.
    After I tested the water a week later, my pool was clear and had 0 FC. heh. I brought out the vacuum and did the pool twice over and adding a gallon of chlorine.
    I have the pump running 3 hours a day. I'll give it another week. Then start to investigate whether or not the filter is actually working properly.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    6,934
    The active ingredient in YellowTrine is Sodium Bromide which brings with it multiple issues. One of the largest is an increased chlorine demand. I would suggest you stop use of this and follow the SLAM process.
    Can you please post a current set of test results and a photo of your water as I'd love to help walk you through fixing your pool.
