Hmm. Make sure you select troublefreepool at the bottom, no commas in your pool volume, and maybe to you need press calculate at the top? Try all that.
Use my numbers above until you get PoolMath figured out. You need at least to hit your minimum FC of 6ppm (unless you are doing another drain...)
