Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Carmondm
    Aug 2016
    Wheelersburg, Ohio
    11
    Carmondm
    I am new to TFP. I ordered the pool test kit and tested my water. I have tried to figure out how to figure out what they mean. Here are my results:
    FC: 7.5
    CC: 1.5
    PH: 7.2
    TA: 70
    CYA: It was half way below the 100
    Can you help me?
    Inground pool, vinyl liner, 16 ft. by 32 ft, with 8ft wide steps, holds 21,000 gallons of water. Installed in 2002, Hayward sand filter, 250,000 BTU gas heater. Davora
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Carmondm
    Welcome to TFP!
    Have you read any of Pool School, specifically starting with ABCs of Pool Water Chemistry?
    How does your water look? Perfectly clear and sparkly? Clear but cloudy? Too cloudy to see the bottom? A green swamp? Pictures are certainly appreciated! The best way is to link to pictures from a photo sharing website or through your smartphone and the tapatalk app.
    Comments on your test results:
    Your CYA is greater than 100. If you want to know how high it is you can dilute your pool water 1:1 with tap water and repeat the test. Multiply the result by 2 to get your actual CYA. However, regardless of what this dilution test tells you, the only way to lower your CYA is to drain the pool. In your case, I'd recommend draining at least half your pool water and refilling. Be sure to always leave 1 foot of water in the shallowest part of the pool when draining though. You want your CYA between 40 and 60 ppm. Using products like trichlor tablets and dichlor shock powders is how CYA gets increased. They both add CYA while adding FC (chlorine) to your pool.
    FC level is too low for sanitation at those high CYA levels. See the FC/CYA Chart.
    CCs are an indication that your chlorine is being actively consumed by excessive organic material in the pool. Either algae or bacteria... or urine/bather waste.
    pH and TA are fine for now.
    Your first order of business is draining water to lower the CYA level.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Carmondm
    Welcome to TFP!
    More here on the diluted cya test, Pool School - Extended Test Kit Directions
    Aug 2016
    Wheelersburg, Ohio
    11
    Re: Carmondm
    I have read the entire site and lots of threads. I just received my Taylor test kit yesterday and I tested my water this morning. I have also read the book that came with the rest kit. I have had a pool for 40 years and I have always taken my water to a local pool dealer to be checked. In all these years, no one has ever told me about CYA levels. I checked it using the 1:1 ratio and the CYA is 160. My water is crystal clear and I have not had any algae or discloration on my liner. What happened was my grandchildren were complaining that the water was burning their eyes. I took a sample to my pool store and he told me I had 0 chlorine and that I needed To raise my TA and add PH down. I added 25 lbs of Akalinity up and 2 lbs of PH down. Then the water turned my grand children's hair green. However the water is still crystal clear. I take another sample to a different pool store and they tell me my chlorine is to high and PH needs to come up. They tell me not to put chlorine in my pool for 3 or 4 days and to add 4 lbs of PH up and to add a bottle of metal remover. I did all of that and after a couple of days I check my water with my little kit that only tests chlorine and PH and the chlorine is still high and the PH is still at 7.2. That's when I found your site and ordered my Taylor Kit. What I was having trouble with was trying to put my numbers in the pool calculator to figure out what I needed to do. But still my water is sparkly clear. I have been using tablets and granular shock for three years. I will try draining my pool down and see if that brings the CYA levels down. I used to use liquid chlorine and tablets but the last three years I have been only using tablets and granular shock. But I have only shocked my pool once all summer. I though since I haven't had any problems with algae or cloudy water I was good.
    Jun 2015
    Glendale, AZ
    156
    Re: Carmondm
    With CYA of 160 you will need to drain 75% of the water to get the CYA to 40
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Aug 2016
    Wheelersburg, Ohio
    11
    Re: Carmondm
    Thank you.
    Aug 2014
    Northern IL
    4,615
    Re: Carmondm
    I hope you decide to trust the forum. We really can get your pool under control and teach you along the way so that you won't even need advise anymore! You will be in control with no more conflicting pool $tore advise.
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: Carmondm
    Green hair means you have copper in the water. Hopefully this has come from using algaecides in the past and will be solved with the water change too
    Incorrect ph or high levels of combined chloramines (CCs) are the usual sources of burning eyes. It was probably the ph unless the pool smelled like chlorine while they were swimming? A chlorine smell is an indication of high CC's
    Dont worry, with the advice available on this site your grandkids will be saying you have the nicest pool ever, my partners grandkids were saying that last year, and you will know it is safe for them.
    Oh, hi and welcome to the site too
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Aug 2016
    Wheelersburg, Ohio
    11
    Re: Carmondm
    Thank you for all your comments. I am fed up with pool stores' advice. I think with is site and the Taylor test kit I can take care of my water.
    DFW, TX
    24,509
    Re: Carmondm
    Quote Originally Posted by carmondm View Post
    We definitely agree with all of that!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Carmondm
    HI! Your wallet is going to LOVE TFP as will your Grands!
    I think it best you do not bother with the book that came with the kit. It is much easier to just use this site. Our info. is based on solid science as well and daily testing in THOUSANDS of pools.
    Have you see this link?
    So much cheaper!
    Let us know of ANY questions or concerns you might have.
    Aug 2016
    Wheelersburg, Ohio
    11
    Re: Carmondm
    I have drained my pool to 6 inches in the shallow end and now I am refilling it. Tomorrow I will retest the water and hope my CYA is better! Then I will have to balance my water. I may need more help!
    Aug 2014
    Northern IL
    4,615
    Re: Carmondm
    Please ask for help!!! It's better to ask and learn! There are no silly questions.
    Have you looked at the Poolmath tutorial? Pool School - PoolMath
    You need only worry about CYA, pH, and FC to start. Initially you will be inputting your test result values for TA and CH in both "now" and "goal" columns. Put zeros for borates and salt.
    Aug 2016
    Wheelersburg, Ohio
    11
    Re: Carmondm
    Yes, I have the pool math nut wasn't sure how to input everything. Thanks for the info and encouragement.
    30,431
    Re: Carmondm
    You will always find people here willing to help.
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Carmondm
    Good morning! How close to being full in your pool today?
    Once it gets full let the pump run for about 30 mins then test your water. We will get your water all set up and looking like a jewel
    Aug 2016
    Wheelersburg, Ohio
    11
    Re: Carmondm
    My pool is full and here are my numbers:
    FC: 2.8
    CC: .2
    PH: 7.3
    TA: 90
    CYA: 80
    Aug 2014
    Northern IL
    4,615
    Re: Carmondm
    Your water is still clear, right?
    If so, according to this important chart, you need to target 9ppm FC: Pool School - Chlorine / CYA Chart
    Why don't you try running those numbers into PoolMath and see if you get that you need 184oz of 8.25%, 159oz of 10%, or 127oz of 12.5%.
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Carmondm
    Your CYA is still a tad high BUT it can be worked with.
    Look at this link please. It tells you all of the levels we like:
    Now this link will help you know how high to have your FC with your CYA at 80:
    Here is a link to my life saver-POOL MATH! I LOVE this thing! It does all of the math for you. There is a learning curve for it so take it slow and let us know what you think you should do before you do it if you have any concerns:
    http://www.troublefreepool.com/calc.html
    Let me know how you do with this info. Does it make sense? Is your pool levels doing what they should when you add stuff?
  20. Back To Top    #20
    Aug 2016
    Wheelersburg, Ohio
    11
    Re: Carmondm
    Yes, my water is still clear. I put the numbers in the pool calculator but I must be doing something wrong, it's not calculating for me. I'm going to try on my computer instead of my iPad and see if that works better.
