Results 1 to 9 of 9
Thread: Question about lowering CYA
    Jul 2016
    Whitesboro, TX
    85
    As I am draining my pool can I test the water for CYA or do I have to drain then refill then test with pool full of water. Finally biting the bullet and lowering it. I used the pool math calculator and it says 50% so that's roughly where I am going with it. Thanks!
    22' Round x 52" deep Coleman AGP, 12,500 gallons. Filled 5-1-16. XtremePowerUSA 4500 GPH 19" Sand Filter w/1.5 HP Pump. Hayward Dyna-Skim In The Wall Skimmer. Hard Plumbed w/2" PVC. PVC Aerator. Pentair Kreepy Krauly Lil Shark Above Ground Pool Cleaner. Whitesboro, TX (North Texas). Taylor K-2006 Test Kit Comp Chorine FAS-DPD. Use The Pool Math App By Trouble Free Pool For Logging.
    Re: Question about lowering CYA
    Quote Originally Posted by GinaLovesSummer View Post
    You're testing for relative levels of CYA. Less water with no other changes = same relative level of CYA. Like when you're testing the level in the pool by using a small sample of water. So 1 ounce of that water is the same as 10,000 gallons. Unless you introduce new CYA-free water to dilute the overall CYA content of your pool it will always read the same.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    domct203's Avatar
    Jun 2015
    CT
    3,589
    No sense checking the remaining water, it will be the same as the CYA is evenly distributed throughout.
    Check it after you complete the refill.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    JoyfulNoise's Avatar
    May 2015
    13,213
    It hurts now but you'll be a lot happier when all that excess CYA is gone.
    Matt
    Jul 2016
    Whitesboro, TX
    85
    That's what I figure. Might as well get it right and slam properly so that when I close for the winter I am not kicking myself for not lowering it. In the beginning of the summer I was being pool stored and that's why I have a CYA of 110. I read it wrong when I first started testing. I figure fix it right this year and hopefully be running smooth next year.
    Jul 2016
    Whitesboro, TX
    85
    The good news is right after I finished draining what I wanted we started getting flooding rains so the pool filled super fast! Woo Hoo! Gonna wait for the sun tomorrow to retest my CYA!
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    357
    EXCELLENT planning!
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    Aug 2014
    Northern IL
    4,615
    Where did your CYA end up, Gina?
    Jul 2016
    Whitesboro, TX
    85
    It ended up at a 60 which I figure at least I can manage for the rest of the season. Plus I will drain part off to winterize once the water gets consistently down to 60 degrees.
