Results 1 to 8 of 8
Thread: Rough housing question?
    nksprts's Avatar
    Aug 2016
    NE Pennsylvania
    140
    Hi all, clueless me again....I was wondering. Tomorrow is my 8 year old sons birthday and he is having friends over. How sturdy are these pools made? Its an Intex above ground 17 round by 52 inches deep. Should I be nervous for about 5 boys to be in there at once, rough housing and jumping around? I always get a bit nervous, just when my son is in there he will jump in and the pool walls you can see really sway around. I have checked after each swim and none of the legs have moved. Just makes me nervous seeing the pool sway like that....should I keep it to a minimal or do you think it is ok?
    thanks in advance.
    nksprts's Avatar
    Aug 2016
    NE Pennsylvania
    140
    Re: Rough housing question?
    also I know you cant really guess how strona pool is vs another, but just looking for some reassurance from people that may have dealt with them.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,008
    As long as they aren't jumping off of the sides or kicking the walls or poles, it should be fine. Get them some squirt guns and let them blast each other!
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    nksprts's Avatar
    Aug 2016
    NE Pennsylvania
    140
    ok thanks, just made me nervous how much they sway and I know boys will be boys.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    I have had a half dozen teenagers rough housing in mine with no trouble.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    nksprts's Avatar
    Aug 2016
    NE Pennsylvania
    140
    thank you both for making me feel a bit better. do you actually see the walls swaying at all? I mean I guess it has to right? Its just a liner being held up by a metal circle.
    Apr 2013
    Sacramento, CA
    2,769
    They are more sturdy then you think. The weight of the water actually is the main strong point.
    As noted above as long as they are not abusing the walls they should be fine.
    A large foam super soaker for each boy and two for you and you will be fine. Diving rings are great also.
    nksprts's Avatar
    Aug 2016
    NE Pennsylvania
    140
    ok thank you all, makes me feel a bit better.
