Results 1 to 14 of 14
Thread: PH readings fluctuate
    Jul 2009
    Flower Mound, Tx
    13
    For the first time in 8 years, my pool PH is varying wildly. Usually in Texas in August, the PH gradually goes up and I add acid about once a week. Now, the PH will read 7.7 one day and 6.9 the next day. I retake it in a different part of the pool, and it reads 7.9.
    I have to take it several times and finally decide based on several different reading whether to add acid or not.
    I have two testing kits and they both seem to read the same.
    Is there a reason that the PH could go down to 6.9 overnight?
    Our pool is 20,000 gallons, temp. 86, Chlorine 6 (I use bleach), Total Alk 60, Calcium 300, CYA 50, plaster pool.
    Barb
    20,000 gal white plaster, w/spa waterfall, DE filter
    38,290
    Re: PH readings fluctuate
    Only if you are dumping in a lot of acid overnight.
    Jul 2009
    Flower Mound, Tx
    13
    No acid overnight. I keep thinking the test kit is wrong somehow but I have 2 that read the same.
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    Are you testing after the pump has been running for a while? How old is the pool? I have read that plaster requires acid when it's new but have no experience as my pool is vinyl.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jul 2009
    Flower Mound, Tx
    13
    And i get different reading at the same time of day just in different part of the pool.
    triptyx's Avatar
    Apr 2016
    1,438
    Quote Originally Posted by JesseSchmidt View Post
    After 8 years, plaster shouldn't really be affecting pH much any more - and if it were, it would be pushing it up, not allowing it to fluctuate.
    The other question is extremely important jkbk - are you testing after the pump has been running for a while?
    Also, what do your returns look like - I'm wondering if maybe there are dead spots in the pool.
    Finally - what happens when you test in the same exact place, same time, every day (assuming the pump has been on for a while)? Are you still getting fluctuations?
    TA is 60, I wouldn't think a TA that is too low could be causing a problem, but you could also try using PoolMath to raise TA to 80 and see if it stabilizes.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    What test kits are you using and how old are they? Do you store your kits inside? Heat and sunlight degrade the reagents.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jul 2009
    Flower Mound, Tx
    13
    Test kit is new. I do test in the same spot with the same weird results but now I test 3 times around the pool. 1 will be low, 2 will be high�� I will bring up TA and see if it helps. The pump runs at least 3 hours before testing. Our pool is 16 years old... Original plaster.
    triptyx's Avatar
    Apr 2016
    1,438
    It's fascinating that your pH fluctuates that heavily.
    I'm back to either:
    1. The returns are misaimed, creating "dead" spots where the chemicals aren't mixing in.
    2. (More Unlikely) - The TA is too low for your particular situation, causing pH flux.
    Honestly, wait for an expert to chime in, no worries! We'll help you get it figured out, but you unfortunately have an "interesting" situation.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    What test kits are you using?
    Karen
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Quote Originally Posted by kcindc View Post
    Ditto.
    Jul 2009
    Flower Mound, Tx
    13
    Taylor Basic residential pool & spa k-1000
    Happened again today. First reading 6.9. Next 4 readings all 7.6
    38,290
    Sounds like your container was not clean for the first test.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I hope you also have the Taylor K-2006 or the TF-100 to test your other chem levels. Pool School - Test Kits Compared
    Extended test kit directions, scroll down to the PH test: Extended Test Kit Directions
    Karen
