Roll call: What cleaner do you use? Are you happy with it?
Summary -- finally!
Here is a really long summary of all the posts on this thread about pool cleaners. I've also included the type of cleaner and an approximate price (the number that popped up in a Google search -- you can probably get it for less by shopping around).
Aquabot Turbo (three posts). Robot. $900
- picks up pollen
- climbs steps, walls really well
- can’t stop it from climbing walls!
- lasts a long time
- inexpensive to run
- works perfectly
AquaBot Turbo 2 (three posts). Robot. $1000
- excellent job of cleaning
- climbs the walls with ease
- tried to eat the cord; easy to fix
- would purchase another one
- gets itself unstuck from the stairs
- picks up leaves, sand, dirt, algae, pollen, frogs, seed pods
- does not scrub pool ledge, steps
- cleans in about two hours
Aquabot Turbo C. Robot. $1000
- wouldn't recommend for Grecian pools; doesn’t clean all parts of pool
- picks up all items
- filter bag is easy to clean
- easy set-up
- great customer service
- eats its own cord
- does not climb steps
Aquabot Turbo T. Robot. $1200
- use for many leaves
- will clean about 1/3 the pool with micro-fine bag, then stops, due to bag plugged
Barracuda. Suction. $300
- very unhappy
Blue Diamond (four posts). Robot. $1200
- lightweight
- moves fairly quickly
- operates silently
- remote control is a waste of the extra money
- great performance
- power supply quit a couple of weeks ago
- long warranty
- only misses steep, angled spots
- picks up large and small debris
- scrubs the liner
- easily climbs walls
- automatically shuts itself off
- nearly perfect
- expensive, but 4 year warranty
Dolphin Diagnostic Advantage. Robot. $800
- does great job
- three year warranty
- climbs walls
- has a sophisticated "brain"
- power cord twists around itself, must be untwisted occasionally
- motor didn’t burn up when twine stuck in drive pulley
Dolphin Dynamic. Robot. $1050
- picks up lots of stuff
- climbs walls
- expensive initial cost
- works great
- uses regular 110v power
Dolphin Explorer. Robot. $800
- does everything really well
- scrubs walls, floors, steps, waterline, no problem with corners
- picks up everything – fine debris, leaves, rocks
- when bag is full, won’t climb walls
- might be slow if under 65 degrees
- 5 year warranty
Dolphin Pro. Robot. $800
- recommend it to others
- does everything well
- 1hr 45 min to clean everything
- leaves, nuts, shells, pebbles are no problem
- expensive.....but worth it in my opinion
Hayward Navigator. Suction. $400
- got stuck on main drain covers
- so-so job
- got caught on the drain a lot
- smallest rocks would stop it from working
- pain to take in and out
- usually wasn't working well
- difficult to adjust suction
Hayward Phantom. Pressure. $900 (w/pump)
- replaced parts (warranty covered)
- skims top, but inclined to break this way
Hayward Ultra (two posts). Suction. $400
- ran for about 6 years
- replaced wings once a year (about $15), shoes every other year ($8)
- leaves, stick, acorns would stop it up
- requires too much suction
- doesn’t work under pool cover
- constantly needs un-jamming
- constantly gets stuck in the corner for 8 hours
iRobot Verro (two posts). Robot. $600
- equivalent of the Aquabot Turbo T
- use fine bag, but fills up quickly
- quite happy with it
- appears to be very robust
- one full season, no problems
Jacuzzi Tracker 4x (two posts). Suction. $250
- great job at lots of debris
- gets stuck under ladder
- low price
- not fast, but does a good job in 8 hour running
- good job on leaves, sticks and acorns
- replace tires each year, $60 a set
- pretty good customer service.
Kreepy Krauly. Pressure (no pump). $300
- have to adjust pressure continually
- got stuck on side, on its own hose
- constant clicking sound
- good budget priced cleaner
- navigates around the ladder, up the wall, in creases/corners
- picks up everything, except the worms
- a bit noisy
- hoses are a bit flimsy, need careful storage
Kreepy Krauly Legend. Pressure. $750 (w/pump)
- goes everywhere, even safety ledge, no problem with corners
- does not climb walls/steps, but could be due to small pump
Letro Legend. Pressure. $575 (w/pump)
- high energy use
- works and works
Letro Legend II. Pressure (no pump). $450
- 7 yrs old
- replaced some small parts recently
- bag wears out about 1-2x/year, new bag is $25
- Velcro on bag wears out; now have seamstress re-sew it with better thread
- hose tangles like a phone cord
Nitro Wall Climber. Robot. $600
- works great
- picks up EVERYTHING
- simple machine
- completely serviceable with a phillips screwdriver
- doesn’t climb all the way to the tile in deep end
- service dept very responsive
- cleaning is simple - rinse bag with hose
Paramount PCC-2000 (four posts). Built-in. $2000
- outstanding job for 10 years
- best money ever spent
- for the first seven or eight years, I thought it was the best thing ever
- pop-up heads wear out, lifetime warranty, but service guy tries to clean them first
- cheaper to get the robot than make repairs
- but helps with circulation for an algae bloom, pool heat, etc.
- can swim while operating
- minimal daily maintenance
- distributes heat and chemicals
- cleans steps and spa
- long run time, lots of electricity.
Polaris 165. Pressure (no pump). $250
- had to replace just about everything
Polaris 180 (two posts). Pressure. $750 (w/pump)
- lasted 15 years
- got hung up in corners
- is at least 20 years old
- have replaced bearings, tires, floats, top cover, housing to backup valve
- did replacements myself
- replaced booster pump last year
- well-built
- easy to maintain
Polaris 280 (nine posts). Pressure. $700
- picks up most everything – leaves, pollen, sand, twigs, acorns, etc.
- uses different bags for different messes
- gets caught on PoolSkim
- doesn’t clean shallow steps, tight corners, swim-outs
- doesn’t get in tight corners
- replacement parts are expensive
- hose comes off sometimes
- 3 years, only one part needed replacement
- stays in the deep end too long
- pick up rocks, acorns, nuts & bolts
- climbs the walls and steps and it never gets hung up anywhere
- pressure relief valve doesn’t work well – replaced with PVC plug
- does not clean recessed steps
- bags, wear rings seem to wear out quickly in gunite pools
- unhappy since day one
- spending $30-$40 every 4 months or so
- doesn’t pick up finest sand, silt, mud using any Polaris bag
- going on its forth season, haven’t had to repair or replace anything
Polaris 360 (three posts). Pressure (no pump). $450
- broke down after 8 months
- loose connector fittings
- water temperature sensitive
- burned a mark into my vinyl liner
- doesn’t back up well
- cleaned absolutely nothing in my pool
- Polaris did not return calls
- rides wheelies, gets stuck in corners, on stairs, doesn't reverse.
- tried to fine tune repeatedly, but won’t work
- Polaris sent replacement parts
- don’t recommend
Polaris 380 (three posts). Pressure. $1000 (w/pump)
- bag fills up quickly
- gets stuck on steps
- picks up almost anything
- bag is nuisance to empty, velcro wears out/gets dirty, opens up in use
- bag fills up and causes unit to fall over and do "donuts"
- parts are expensive, tail sponges don't last
- booster pump runs up electric bill.
- hoses come apart and disconnect several times
- doesn't seem to get the shallow
The Pool Cleaner, 2-wheel (two posts). Suction. $400
- doesn’t get stuck
- doesn’t clean steps/benches, or in shallow water
- climbs the walls well, until filter needs cleaning
- had to disassemble and clean the gears to get wheels to turn
- works perfect
The Pool Cleaner, 4-wheel (five posts). Suction. $400
- low energy use
- small bag
- gets stuck in deep end, on edge
- cleans everything but the steps
- best cleaner ever owned
- amazes me
Pentair Pool Shark. Suction. $400
- pleased so far
Pentair Great White. Suction. $300 - $400
- very useful
Tigershark QC (two posts). Robot. $900
- climbs walls well
- cleans very well
- extremely happy with it
- self contained filters - just hose off
- cleans every square inch except the first step
- climbs walls well
Zodiac G4 (two posts). Suction. $375
- nightmare trying to get it to work correctly
- but now works fine
- climbed walls
- stayed at water line all the length of the pool
- sometimes got stuck at the corner step
- used it over 2 years now
- had to replace the diaphragm
- *highly* pressure sensitive
- your sand filter needs backwashing if the G4 slows down
- rarely get stuck on the 2nd step
- happy with it
- haven’t replaced a part in 24 months
1) What pool cleaner do you own?
Dirt Devil Pro-V
2) Do you recommend it to others?
Yes, as a budget cleaner
3) What does it do really well?
Gets small debris very well, easy to 'tune' to the available suction, no bags, wheels, etc. Never gets stuck, though my main drain is mostly closed. Good random pattern, gets the whole pool up to the water-line, even gets all but the top step.
4) What does it do NOT so well?
Gets jammed on large debris: twigs, acorns.
This is my first cleaner, $100 after rebate last fall, for the price I figured I couldn't go wrong!
It would be perfect for a pool which only gets small debris, like those living in the desert who mostly get sand/dust in the pool. Not as good for those of us with lots of trees etc. Combined with the $35 "Pool Devil" skimmer, which catches most of the big stuff before it gets waterlogged & sinks, it works well.
1) What pool cleaner do you own? Polaris 360
2) Do you recommend it to others? Yes, but I'm hearing that there are others that might work much better.
3) What does it do really well? (e.g. picks up dust, acorns, climbs walls, steps, etc.) It really picks up all the stuff on the bottom, right down to the small dust/dirt/hair particles that I'm not even seeing in there.
4) What does it do NOT so well? (ditto) I love the quick connect plug. The swivel joints on the hoses are great so that the hose doesn't get all twisted, but I find they leak all the time. It also has a tendency to get stuck near the steps, although every 3 minutes the backup jet kicks in and pulls it free. But I saw someone else post (and I agree) that it spends perhaps too much time floating around the pool from the backup jet, rather than cleaning. I only have a single 2-HP pump for everything and so I find I have to direct almost all of my return water to the cleaner to make it work.
Re: Summary -- finally!
- low energy use
- small bag
- amazes me
Just FYI, my Pool Cleaner was a 4-wheel pressure-side cleaner, not suction.
Oops ... I thought that 4x meant 4-wheel, and was getting the 4x and the 4-wheel mixed up. So, that section of the summary is a bit goofy. Anyone wanting to purchase The Pool Cleaner (aka Poolvergnuegen) should read the actual posts, instead of the summary.
4x does mean 4-wheel, but The Pool Cleaner has the following three main options, one of which is a pressure-side cleaner:
2x Suction PoolCleanerâ„¢ (this is 2-wheel)
4x Suction PoolCleanerâ„¢ (this is 4-wheel)
Pressure PoolCleanerâ„¢ (this is 4-wheel)
I have been eyeing this thread and want to interject a question.
Does a good pool cleaner scrubs the sides enough so you don't need to routinely brush all the walls?
If so, that would cinch it for me.
thanks
Evan
Blue Diamond
Yes, but I have limited experience with other brands, so the recommendation is somewhat suspect
Fast, excellent on very small debris, never gets stuck (drain covers or floor returns), cleans the whole pool up to the top of the waterline tile.
Fails to climb/clean steps or swim-out, still have to manually brush them.
If the robot and its power center are out of the cart, it will fall over from the weight of the handle. I need to add something weighty to the bottom/front of the cart.
