Results 1 to 10 of 10
Thread: Got my TF-100 kit, what now?
    Jul 2016
    Easton, PA
    6
    Should I remove the tablets from the chlorinator to do the testing, or keep things as they are now and run the test? I did have a test conducted at a pool store, they said all was well. But in my readings here I have found that they are not very reliable.
    Thanks!
    IG, 22000 gallons, plaster, sand filter, TF100 test kit
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,253
    Re: Got my TF-100 kit, what now?
    Welcome to TFP! Good to have you here
    You can leave everything as-is and test anytime you like. I hope you're considering a switch to liquid chlorine. Here's a couple of links, including one that describes TFPC and the other has the complete testing instructions.
    TFPC for Beginners
    Pool School - Extended Test Kit Directions (note that this includes OTO chlorine which we generally just use a a spot check for "any FC at all". The one we report here is the FAS-DPD test which uses powder and then drops.
    Come on back and report your numbers here, looking like this:
    Example only
    FC 3.5
    CC 0.0
    pH 7.8
    TA 100
    CH 300
    CYA 50
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Run a full set of tests and describe your water condition, clear, cloudy, green etc
    I would take out the tablets and start dosing with bleach to obtain your target chlorine level as per this chart Chlorine/CYA Chart
    Heres the link to the video site describing how to do the tests: https://www.youtube.com/user/TF100TestKit/videos
    Once we know what your levels are and how the pool looks we can then make recommendations
    Oh and welcome
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Jul 2016
    Easton, PA
    6
    I am planning on switching to liquid chlorine, I have only been in the house for 2 weeks. I am unsure if I want to transition to liquid this close to the end of the season, or just start new next year. I will post my results hopefully tomorrow.
    Quote Originally Posted by needsajet View Post
    TFPC for Beginners
    Example only
    FC 3.5
    CC 0.0
    pH 7.8
    TA 100
    CH 300
    CYA 50
    Thanks!
    Jul 2016
    Easton, PA
    6
    Ok, ran the test, and here is what the results were.
    FC 4.6
    CC 0.0
    pH 7.6
    TA 50 (ran this test twice as it turned yellow instead of red)
    CH 375
    CYA 120
    As expected my CYA is through the roof, I assume from the tablets.
    FC 4.6
    CC 0.0
    pH 7.6
    CH 375
    CYA 120
    Thanks!
    30,421
    What does your water look like?
    Jul 2016
    Easton, PA
    6
    Water is clear and sparkling
    Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here are some more detailed testing to review for TA, Pool School - Extended Test Kit Directions
    With only 2 weeks to go dealing with your cya at closing and opening isn't a bad plan. It needs to be around 40. Using dichlor or trichlor will increase cya.
    Jul 2016
    Easton, PA
    6
    Quote Originally Posted by pooldv View Post
    I guess I will plan to drain some water prior to closing it, then refill upon opening. I had planned on using the liquid bleach and methods found here, but with the move and working, I opted to continue with what the old owner was doing.
    Anything else I can do prior to closing to assist with the process?
    Thanks!
    DFW, TX
    24,497
    More about closing here, Pool School - Closing an In Ground Pool
