Thread: Noob needs help
    Jul 2016
    Broken Arrow Ok
    1
    Post Noob needs help
    New to the pool maintainence part of swimming pool. I have shocked my pool with 2 different types of products,one was leslies powder plus and the other clorox extra blue for what I thought was a mustard algae outbreak. The clorox product cleaned the water up nicely but when the dust settled there was my problem again. I'm beginning to wonder about what my problem really may be,if not algae,maybe pollen??? When I first started using my sand filter it seemed fine and after a couple of weeks it doesn't seem to filter out the finer particulates now. Question: what does algae turn into when it's dead and how is it removed,same for pollen?? When I vacuum it turns into a watery dust cloud and in the morning there it all is again should I just exhaust? Do you have to "slam" all algae outbreaks or will algicides do the trick? Thanks for any help
    Jun 2016
    Panama City
    100
    Re: Noob needs help
    I'm new myself, but I can point out a few things. We need to know the basics of your pool, asking questions is great but the BBB method (bleach, baking soda, borax) is hinged on your test results and not using anything that's not BB or B! If your pool is temporary or permanent, IG or AGP. What test kit are you using and all your routines with your pool. This forum has a ton of folks that can help! They will be along shortly, lol!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    Re: Noob needs help
    Welcome to TFP! Good to have you here
    Most filters can filter out the dead algae but it's slow. Dead algae looks like clouds of whitish or bluish dust which settles on the bottom when the pump is not running. You can usually suck it up by moving the vacuum head very slowly, then brushing to get it all into suspension so it can get to the filter. JEC above offers some good tips. You'll get the best possible advice by following the instructions in "Read Before Posting" which is linked in my signature below.
    You might also enjoy this description of Trouble Free Pool Care (TFPC): TFPC for Beginners
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: Noob needs help
    Quote Originally Posted by Bohunkus View Post
    Welcome to the forum.
    What you have now is all the dead algae on the bottom of the pool. Keep your filter running 24/7 and continue to vacuum & brush. The answer to your troubles is good old liquid chlorine.
    Leslies powder plus is Cal-Hypo, meaning it added calcium as well as FC to your pool. The Clorox Extra Blue is Trichlor, adding CYA to your pool. Do you have a plaster pool?
    At TFP we never 'shock' our pool, and if there is an algae bloom we will SLAM the pool (http://www.troublefreepool.com/conte...tain-shockingl)
    Please tell us about your pool, size, volume, equipment, etc as it will help with the advise given. It is best to put this info in your signature line.
    http://www.troublefreepool.com/conte...efore-you-post
    How do you normally test and chlorinate the pool?
    http://www.troublefreepool.com/conte...nate-your-pool
    Glad to have you here.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2012
    Montville NJ
    545
    Re: Noob needs help
    I run a DE filter, so I cannot speak from experience, but many people report that adding a bit of DE to their sand filter helps with trapping the small particles.
    However, first, do as others have said. Get a good test kit, read the pool school section, and then come back here. Without knowing about your set up, and the current chemistry of your water, it is pretty much impossible to recommend a course of action.
    Thanks
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Noob needs help
    Welcome to TFP!
