Thread: Using Media Blast to Clean Flagstone
    pattenpool's Avatar
    Jun 2014
    The Woodlands, Tx
    6
    I would like to get some input as to an issue that occured with a neighbor's pool. The pool is standard freshwater with a DE filter, raised wall with flagstone in rear and flagstone around waterline. They contracted a reputable company to remove the calcium buildup on the stone and to acid wash pool. The crew did a great job on the stone using red garnet and afterwards did an acid wash on the quartzscape. When the contractor finished and was putting CYA in skimmer, apparently it came back out via the returns. The filter is a Pentair FNS with obvious openings in the grids or manifold.
    Questions is, is there anyway for the stone cleaning and acid wash process to blame for damage to the filter grids? The contractor did use a deck pump to get most of the red garnet out, however there was some in the filter when it was opened. A trash pump was used to drain the water/acid out. The neighbor is blaming the contractor and asking them to pay for the new grids which their pool maintenance company is telling the neighbor everything was fine before the stone cleaning.
    JoyfulNoise's Avatar
    May 2015
    13,213
    Re: Using Media Blast to Clean Flagstone
    I think the policy of TFP is not to get involved in disputes like this for obvious legal reasons. This is something that has to be worked out between your neighbor and the company that did the tile/pool cleaning work. I have never heard of garnet blasting for stone cleaning as I would think garnet would be highly abrasive and permanently etch the surface of the stone, but maybe that's what was needed. I suppose a hard material like that could cause problems with equipment (I'd be worried more about damage to the pump than the filter) but there's no way to know that just based on what you describe. I doubt any failure analysis could determine a direct link between the two.
    Sorry, it's really an issue for the parties involved to come to terms with.
    Matt
