Thread: Pump dead?
    Jul 2016
    Wesley Chapel
    34
    Pump dead?
    I must have jinxed myself asking about re-plumbing for when my pump died because I am afraid it might have - but not sure. I have a Haywood Northstar pump 1.5 HP. When I came home I noticed it wasn't working. There is a loud HUM that comes out and it is SUPER hot. The hum doesn't stay on...it just hums for a few seconds and then goes quiet. WE recently had the pool re-done - is it possible something just got stuck in the impeller? The pump died 2 years ago and the company that fixed it put in a century Centurion motor. It was 5-6 years old at that time. Is it time to just get a whole new pump? If so, what is a good replacement for the Haywood Northstar 1.5 HP? We have a suction cleaner, SWG, two pot/waterfalls and bench jets....not sure the VS speed would work with all that, would it? NO sense in getting something that has to run on full power all the time, is there?
    Is there hope this can be salvaged?
    Greg
    15' x 30', 13.5K Gallons, Pebble Sheen, 2 Deck Jets, Haywood 4820 DE Filter, Haywood Northstar 1.5 HP Pump, Haywood T-Cell-15, Haywood Heat Pump, Haywood Navigator Pool Vac
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Pump dead?
    More than likely it is just a bad capacitor. Can you turn the impeller easily (by hand)?
    Mark
    Jul 2016
    Wesley Chapel
    34
    Re: Pump dead?
    Quote Originally Posted by mas985 View Post
    So I have never taken a pump apart before😋 This thing is a beast. I finally managed to take it apart and was able to turn the impeller by hand. Putting it back together was even harder. Should I replace the O-ring? I guess I will see if it leaks - if I can even get it going again. So if the impeller turned does that mean it is the capacitor? Amazon has one for $15. I might order there - not sure of any place around me that would carry them. Do you think that is worth a shot! (If I haven't totally destroyed it already by taking it apart and putting it back together?)
    Jul 2016
    Wesley Chapel
    34
    Re: Pump dead?
    Quote Originally Posted by cannelg View Post
    Thanks for the tip. New capacitor fixed it! The old one looked as if it exploded. New one works great. Only problem is that the the plastic piece that covers the motor is cracked! Do they sell replacements for just that cover to the wiring?
