Results 1 to 7 of 7
Thread: Friend's pool...does this look like 35,000 gallons?
    Jul 2012
    Herndon, VA
    419
    Friend moved into their house in July, opened pool a few weeks ago.
    Anyway, the previous owner said the pool is 35,000 gallons.
    Below is a picture. Deep end is 9 feet. Does this look like 35,000 gallons?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    30,421
    Re: Friend's pool...does this look like 35,000 gallons?
    Yes. Value of that answer based on the picture? Zero.
    Apr 2013
    Sacramento, CA
    2,769
    It could be 35, it could be 30. 35 is a large volume for a backyard pool. The way you figure it out is divide the pool into sections, determine the volume of each section add them up to get thew estimate. Then treat it if its that size. Adjust the size based on chemical usage.
    Jul 2012
    Herndon, VA
    419
    I told her I'd assume it was 30,000 gallons, and use that for calculating intitally with the pool calculator.
    That being said, I tested her water, and he CH was 110. This is a gunite pool, so based on recommended levels, she'd want to get that up to 250, right?..roughly 42 pounds of this?:
    Amazon.com : Snow Joe MELT25CCP 25-LB Professional Strength Calcium Chloride Pellets Ice Melter Resealable Bag : Patio, Lawn Garden
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Could be. You could figure it out with bleach and pool math.
    I.E. Measure FC, add 1 gallon (or any amount) fresh bleach, measure FC again 30-60 mins later, then take the difference and figure out what volume that corresponds to in pool math
    When adding Calcium start with like 1/2 or 1/3 of what you think you need... ya can't get that stuff back out.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    That's a commercial diving board. To meet diving specs, the pool has to be pretty big.
    What is the smallest rectangle that the pool can fit in?
    Support the site
    Apr 2013
    Sacramento, CA
    2,769
    I agree with pinguy add calcium s l o w l y . First one half what you need then a bit more. Creep up and be a little bit on the low side.
