Thread: Aqua-Rite not working;no power lights, no display
    gonefishin's Avatar
    Joliet, Il.
    413
    Hello all!
    I ran through the Aqua-Rite Troubleshooting guide, did the voltage checks (page 9-12)...everything went as discussed in the troubleshooting guide. It advised me to buy a new DSP board. Off to Amazon I go...I just got it today, installed it...and it doesn't work! Same problem. No power lights, no display.
    Really kind of upset I spent the money on the board, if anyone can help I'd appreciate it!
    Dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    gonefishin's Avatar
    Joliet, Il.
    413
    Re: Aqua-Rite not working;no power lights, no display
    Just got off the phone with a Hayward Tech. He had me run through the voltage checks and said I need a new main motherboard. The Hayward troubleshooting guide told me specifically to replace the DSP. All checks done with the Tech were the same, and consistent, with the guide pointing me to the other part. I should have called first, but the guide seemed to be complete and from Hayward...very contradictory advice though.
    He said it carries a 3yr warranty. Now do I find a service center and pay for labor...or order the main board and install myself. Any idea what labor could be to replace a motherboard?
    thanks,
    Dan
    33' Aqua-Leader AGP
    Aqua-Rite t-15 SWG
    gonefishin's Avatar
    Joliet, Il.
    413
    I got a quote back on a local pool Hayward Service Center, they said a little over $500 since I already troubleshot with Hayward, it would be more if they needed to troubleshoot. The Hayward Warranty is really worthless when in warranty service is this much money! A new motherboard, on Amazon is $175, if I'm remembering correctly.
    I did purchase a new thermister and changed it out...did not correct the problem. Still no lights and no display.
    So now, do I go ahead and replace the main motherboard, or purchase a new main unit (minus cell). Voltage checks all seem fine for the transformer checks and rectifier, according to the Hayward troubleshooting manual above. But as I've already found out...the voltage checks supposedly shown the transformer and rectifiers were good. At least the voltage checks in those areas.
    I'm at a loss as to purchase a new unit or go ahead with the motherboard.
    Further inspection on the motherboard showed no signs of part distress or damage. Motherboard appears, only visually, to have no burnt/blown components and no bulged electrolytic capacitors.
    Dan
    33' Aqua-Leader AGP
    Aqua-Rite t-15 SWG
