Thread: green pool!!!! please help.
    Aug 2016
    chandler az
    11
    I hope I can get some help. my pool had recently turn green and I replaced my DE fileter with a cartridge filter. So, I ran and got the water decent but then all of a sudden it's back to being green. A few days ago I bought 2 lbs out "yellow out" and 4 gallons of chlorine. Ran the filter for 24 hrs and water still green. I also just yesterday cleaned the filters and added 7 bags of pool shock. What else can I do? please help.
    chlorine pool
    15,500 gallons
    in-ground
    Pentair cartridge filter
    1 hp motor
    May 2015
    Land O Lakes, FL
    527
    Re: green pool!!!! please help.
    Can you post a set of test results.
    What we need to know to answer your questions
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,549
    Green water is a chemical problem, not a filtration problem. More specifically, you have insufficient chlorine (FC) relative to your stabilizer (aka CYA) level. As stated above, we need a full set of test readings before we can make any suggestions other than to add more chlorine to your pool in the form of liquid bleach.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Aug 2016
    chandler az
    11
    the reading are as follows:
    CL .5
    Br 1
    Ph 7.0
    chlorine pool
    15,500 gallons
    in-ground
    1 hp motor
    May 2015
    Land O Lakes, FL
    527
    Hello, unfortunately, we are really going to need a some test results from one of the recommended test kits.
    Pool School - Test Kits Compared
    TF-100 is the most liked and best value TFTestkits.net
    In the meantime, add 2 gallons of bleach now and then about 3/4 of a gallon each day until you get a kit and can post some numbers. Keep you pump running and brush. You mayl get some kill off of the algae with this but you won't be able to complete it until the test kit comes.
    Matt
