Results 1 to 7 of 7
Thread: Hayward VS pump issue
    May 2015
    Lake Elsinore ca.
    48
    Pump is about a year old. Can home yesterday to find the pump off. Tried to start it but only rattles and clicks like some is stuck inside. Open and cleaned basket but nothing inside. Any ideas?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Hayward VS pump issue
    You may need to take the pump's wet end off the motor to fully inspect the inside of the pump.
    Mark
    Jun 2016
    Oklahoma City, OK
    49
    The impeller might be clogged. You could check by cutting power to the pump completely and checking the impeller with a long needle nose pliers or screwdriver and inserting it in the suction hole of the housing... Only do this after ensuring power has been cut off namely at the breaker panel.
    May 2015
    Lake Elsinore ca.
    48
    Appears that the impeller won't easily turn. Sounds like the bearings seized not I need to figure out how to get hayward warranty process.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Bearings should not fail with a pump where the warranty is still good. Did you take apart the wet end to make sure there is nothing stuck in the impeller?
    Mark
    May 2015
    Lake Elsinore ca.
    48
    Had someone take apart to make nothing was stuck and he said impeller won't easily turn and nothing was stuck.
    May 2015
    Lake Elsinore ca.
    48
    Not sure exactly what failed on the pump but it's back up and running thanks to Hayward warranty. I notice a new back cover on the dry side of the pump. I know a 1 year old pump shouldn't fail but it's great having a manufacturer stand behind their products. I called the builder expecting to get "sorry for your problem " line and just getting a random warranty hot line number for me to get in touch with Hayward. Instead my builder worked with a Hayward technician to schedule a repair in no time.
    Only had one other issues with equipment (Aqua Pod)that one of members here help get replaced.
