Thread: New to TFP
    KenFirch's Avatar
    Aug 2016
    Sacramento CA
    16
    New to TFP
    Hello all,
    First post here. After paying a pool guy for several years at $55/month to just handle the chemicals, I've decided to go the TFP route. We just finished remodeling our 25 year old pool, basically everything except digging the hole and gunnite. Equipment listed in signature. Pool was finished late July, and just had the startup process completed and salt added. I ordered the K-2006 test kit and SpeedStir, but in hindsight should have gotten the TF-100. Im now trying to dial in the SWG, IntelliPH, and pump runtimes. I just installed the IntelliPH yesterday, and have it dialed way back for now. Here are my current readings:
    FC 6.5
    CC 0
    pH 7.6
    TA 80
    CH 220
    CYA 45
    SALT 2900
    So, using PoolMath, my immediate needs are to slowly raise my CYA to ~70, then a day or 2 later get my CH to ~350.
    Just want to make sure Im right track.
    Thanks, Ken
    25,000 gal IG rectangular, quartz, re-plastered 7/2016
    Pentair equipment: VS pump, 520 filter, IC40 SWG, IntellipH, EastTouch 8, wireless control.
    Polaris P955 robotic cleaner. Taylor K-2006C. Solar Breeze NX.
    Future: Solar panels
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: New to TFP
    Welcome to TFP!
    Looks like you've done a lot of homework here already! Nicely done. That's half the battle. Just trying to absorb what we teach here without info overload. Once you put it into practice, it all comes into focus rather quickly. You're doing it right but might want to target 60 ppm CYA first, then sneak it up to 70 ppm after that.
    Great looking pool!
    Isolated Spa - 345 Gallons
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Re: New to TFP
    Wow, nice pool!
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    May 2015
    Land O Lakes, FL
    527
    Re: New to TFP
    Very nice pool.
    Here are a couple of tips to dial in your run time.
    1. Keep increasing your CYA until you get to about 70.
    2. Keep you FC at least 2 ppm higher than your target until you know that you have the run time / SWG % set right. Use bleach to get it to this point and then the SWG will keep it there.
    3. Use the chart below to determine the run time / SWG %. In CA, this time of year with alot of sun and CYA of 45, I would be using 3-4 ppm as the starting point.
    Other:
    Your PH will constantly climb due to the SWG outgassing and new plaster. For the 1st few months of my new plaster, I was told to keep the PH on the low side. I would adjust to 7.2 and then when it climbed to 7.6-7.8, I adjusted it back down.
    Your CH is probably a little low but not drastically. See the recommended levels (350 - 450). Just keep in mind that if you need to add water due to evaporation, if the CH is high in the water, then it add as well, so you need to know what your fill water CH is.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    KenFirch's Avatar
    Aug 2016
    Sacramento CA
    16
    Re: New to TFP
    Thanks! This site has been a wealth of info so far.
    Quick question on the SWG...even if the pump speed is as low as ~1700 rpm, the SWG still generates the same amount of chlorine, right?
    Right now I've got it programmed to run at 1700 from 8:00 am to 12:00 pm, then up to 2600 rpm until 3:00 pm.
    Ken
    May 2015
    Land O Lakes, FL
    527
    Re: New to TFP
    Quote Originally Posted by KenFirch View Post
    Ken
    Correct
    Matt
