Thread: Vacuum vs brush during SLAM
    Jun 2014
    Marietta, GA
    102
    Is there an order to the process of algea removal? I have SLAM'ed before, so I know that process. First I vacuumed as much of the algea to waste as I could. Then had to fill the pool. Then I started the SLAM. During the SLAM, I am getting more algea on bottom. Can I get away with just brushing frequently, and keeping my FC at the shock level, or do I need to keep vacuuming everything I can see to waste, then brushing? Vacuuming to waste delays the process, because the water level drops below the skimmer, so I need to refill the pool before I can run pump on skimmer/drain, so there are hours that I am only running pump on drain before level is high enough to switch to skimmer. Plus, brushing takes a lot less time than vacuuming, and i really don't have enough time to vacuum daily or even more than daily. Pool is really bad cuz pump broke, and had to order new one, so there was no pump running for about 10 days.
    27k gal, IG vinyl, Pentair Triton II Sand Filter, 1 HP Hayward Super Pump, Liner 3 yrs old, Intermatic PF1103T Timer w/ Freeze Protection, K-2006.
    30,432
    Re: Vacuum vs brush during SLAM
    Stop vacuuming to waste. Your equipment is intended to get your pool clean and keep it that way.
    Vacuum in the filter position and then backwash each time your psi goes 25% above the clean psi. Vacuuming to waste is usually uneccessary and always very wasteful and time consuming.
    Jun 2014
    Marietta, GA
    102
    duraleigh, I am so glad to hear you say that. It is such a pain to vacuum to waste. That being said, should I vacuum daily if I see a lot of algea on bottom, and brush as often as I can, or will the SLAM do its job the same by simply brushing?
    30,432
    If I understand your question, you should vacuum as often as required to keep the pool floor clean. The SLAM will actually deposit more dead algae on the floor so use your vac to get it into the filter.
    As your SLAM takes effect, there is less and less algae to kill so subsequently less dead algae on your pool floor.
    Vacuuming and brushing are an essential part of the SLAM so do them often but we all have lives to lead, too.
    May 2017
    Atkinson, NH
    84
    The lady at the pool store told me to brush and filter to waste then turn the filter on after. She said dont' turn the filter on until the pool is blue. So I should use the filter and backwash when necessary? Im so confused...
