Results 1 to 7 of 7
Thread: swimming while SLAMing
    Aug 2016
    indianapolis/IN
    3
    Question swimming while SLAMing
    Is it safe to let swimmers in the pool while SLAM is in progress?
    16,000 freeform plaster, sand filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: swimming while SLAMing
    Yes, it is safe to swim when
    FC is above minimum and up to shock level for your CYA, FC/CYA Chart
    PH Is 7.2 to 7.8
    Water is clear
    We had a swim-n-slam last summer with FC 28ish and CYA 70 and nobody even noticed. FC at shock level for your CYA is less harsh than a pole with no CYA and FC of 1 ppm. CYA greatly buffers the chlorine harshness.
    Aug 2016
    indianapolis/IN
    3
    Thanks!
    A related question for me here, (I got my CYA a little high), I was at Leslie's pool store and they told me that CYA "hangs out" in the top 6" of pool water. Therefore, flushing water to waste from the skimmer would be a quick way to lower my CYA level.
    Would you concur?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    That is total nonsense. Please avoid that store in the future for anything other than inflatable pool toys.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    30,419
    Bogus! Bogus! Bogus! CYA "hangs out" in suspension throughout the entire column of pool water and it doesn't settle to the bottom, either!
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    CYA is mixed throughout the entire body of water. It's only going to lower the CYA level proportionally to your water volume. See Pool Math at top of page. Visit Pool School.
    You have on of the recommended test kits if you are slamming, correct?
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Aug 2016
    indianapolis/IN
    3
    You guys are such a help!!
    Many thanks
