Results 1 to 9 of 9
Thread: Solar cover reels - advice/recommendations needed
    Jun 2016
    Suitland, MD
    18
    I need some sort of reel for the solar cover because I can't handle it by myself. I have a 24' round IG pool with an irregular pool deck (sort of homemade cement pavers) so I can't exactly bolt anything down.
    Sue from Maryland
    13, 000 gal. 24 foot round pool, vinyl, in-ground (no main drain), Hayward sand filter, 3/4 hp pump, Aquabot s2-50
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Solar cover reels - advice/recommendations needed
    Here is the local fave diy cover reel. Should work great for your application.
    DIY Solar Cover Roller
    Jul 2015
    Central Valley CA
    1,109
    I did the DIY cover only thing I changed was I used stainless steal screws with pieces of pipe as washers instead of the auto clips. I could not find a source for the clips that was not expensive, would have more than doubled the cost of the build in my case.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2016
    Suitland, MD
    18
    Quote Originally Posted by pooldv View Post
    Not sure if I quite understand... it's a floating pipe with the cover attached? I have no idea how to attach the cover. Also if I did something like this would it be best to cut the cover in half?
    Sue from Maryland
    Jul 2015
    Central Valley CA
    1,109
    You got it, it is a pipe under the middle of the cover. I cut little pieces of pipe to use as washers and used stainless steal screws to sandwich the cover between the pipe and homemade washers every 2ft or so. You just twist the pipe and the cover rolls up from both sides at the same time. You have to cut the cover in half as a 24 foot roll would be too much strain on the pipe and would be unwieldy to lift out of the water. Most of the time We just leave the cover in the pool rolled up if we are just hanging out on the shelf. I take it out on weekends or if we are having people over.
    Jun 2016
    Suitland, MD
    18
    Quote Originally Posted by atttech-2 View Post
    OK I think this might be something I can handle doing. What kind of pipe should I use and how big? Do you have a picture?
    Sue from Maryland
    Jul 2015
    Central Valley CA
    1,109
    I used 1 & 1/2" ABS DWV same as mas985 you can usualy only find it in 10' lengths so you will need 3 of those and couple of couples to to create 2 12 ft sections.
    Jun 2016
    Suitland, MD
    18
    I can't find ABS DWV anywhere local would PVC or something else work as well?
    Sue from Maryland
    Jul 2015
    Central Valley CA
    1,109
    I would think that PVC would work, it's going to be a bit heaver but since the weight is distributed I don't think it will matter. You could try 1" instead of 1.5" the other thought I have is put the pipe on the top of the cover instead of underneath to distribute the weight even more. It will not be as aesthetically pleasing but should work. You can PM mas985 I am sure he has heard of different variations on his design.
