Results 1 to 9 of 9
Thread: Build up at bottom of the pool - Pictures
    May 2015
    Burbank, California
    66
    My readings (T-2006)
    FC - 12.5
    pH - 7.4
    TA - 180-200
    CH - 750
    CYA - 80-90
    In the last week, I was having issue regarding yellow algae. I raised my FC from 4.0 to 12.5. My pH was at 8.0, now it's 7.4. Even after sweeping the pool with a brush. There are areas on the bottom of the pool that look like dirt, but isn't. I don't know what it is. Hopefully these pictures can show you what i'm talking about.
    A few years ago, we removed all the water from the pool and did an acid wash. The pool looked perfect. Now there is scaling at the bottom of the pool that doesn't brush off.
    Any ideas?
    23,000 Gallons Plaster Pool & Spa (1989). Hayward Super II 1.5 HP Pool Pump (Single Speed). Cartridge filter. Kit Tester: Taylor K-2006.
    May 2015
    Burbank, California
    66
    Re: Build up at bottom of the pool - Pictures
    Another thing I want to address is CH - 750. I test the water the refills the pool, and the CH is at around 200-220.
    We have a large water softener that works for the house. If I were to use pool water for gardening and then refill the pool using water from the water softener. This would help me lower these levels correct? Any downside to doing this? Seems like the cheapest alternative, and my City won't notice a huge spike in water usage.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    Scale, and it looks like you still have algae as well.
    Your TA, pH, and CH were all very high which caused the scale to build up. There is nothing wrong with each of your numbers but when you combine them together, they potentiate eachother and make for water that is oversaturated with calcium carbonate. You can attempt to drastically lower the TA and keep the pH around 7.2 in hopes to dissolve some that scale but it will be a very long and slow process. Your best chance of removal is likely another acid wash but may not be possible based off the condition of your plaster.
    If you had algae and only raised the FC to 12.5 then you did not kill everything in the water. With a CYA of 80, you should be maintaining a FC level of 34 until you pass all of the SLAM criteria.
    Where are you located in CA? How old is the plaster?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Just remember the water softener can only hold/treat ?? amount of water. Once you have reached that amount you will be using "regular" water again until the softener recharges.
    Run your numbers through Pool Math. Look at the CSI area towards the bottom. Share that with us and we can go from there with your "staining" or what ever it is.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    Quote Originally Posted by SickestGuy View Post
    That would take forever. To lower your CH level, you would have to drain 75 % of the pool and that would get you to the 400 ppm range with your full water CH level. A residential water softener was not design to process that large of a volume of water. There are reverse osmosis companies locally that filter your water of the CH without draining the pool.
    With a pH of 8 and your current numbers, your CSI is 1.12 which is double the level where scale occurs. Your CH is easily manageable (mine is higher than yours) but you can not have high calcium levels with very high TA and not expect scale to form.
    -Brian-
    POOL BUILD
    May 2015
    Burbank, California
    66
    Quote Originally Posted by kimkats View Post
    Yea, I know how the water softener works. I wasn't planning on hooking up a hose to it or anything. Just replace the water slowly.
    Quote Originally Posted by bdavis466 View Post
    Ok, I will get the pH down to 7.2. If it's a long process, that's fine. No one uses the pool right now, and hasn't for years. But when you say long, what do you mean by long? We can't do another acid wash due to our city not allowing us to empty our pool.
    Can't empty the pool like I said before. City isn't giving out any permits to empty the pool. My idea of using our water softener to place to the water, in my head was smarter because, there is 5-10 ppm calcium level. And the water coming from the city is like 200-220 ppm.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    It would take months to years to dissolve the scale and would require much attention. If you got the CSI low enough to do so, you'll also be dissolving some of the plaster.
    High calcium levels get blamed for scaling issues but in reality its a combination of the pH, TA, CH and water temp (ultimately CSI). Lowing your calcium level alone will not solve the problem as you can still easily have scale with a CH level below 250. This is why frequent testing and staying on top of water chemistry is so important.
    What city are you in?
    -Brian-
    POOL BUILD
    30,421
    +1 what bdavis is telling you. You are beating your head against the wall.
    If you cannot think of any way to do a partial drain, I would suggest you forget about the stain removal project and simply start refilling your pool from the spigot with the softener. In a couple of years your pool should look great again and it will only cost you the price of the softened water.
    As stated above, you must carefully monitor pH through out this time and keep it around 7.2
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    Just a thought that might help on the ch end:
    This tool has been used by other posters in the past to use MA to remove copper staining, but it should in theory also help remove scale buildup : Amazon.com: Purity Kit Underwater Acid Wash UAW: Home Audio Theater
    In the event that the bottom staining is a combo of calcium scale and iron (eg are you on a well?) or copper, this approach may also clear up the stain if in fact the stain is not organic.
    You mentioned that the staining doesn't brush off, but there is also some discussion of algae...perhaps performing an Overnight Chlorine Loss Test will help you get to the bottom of that one.
    Lastly, is your softener a single or dual unit? I switched to a dual for constant regeneration capacity and was able to pretty much convert my pool to soft water over time. If yours is a single and if your ch builds up fast, upgrading to a dual system is an option, though not especially cheap do you have an outdoor spigot to whch the softener is actually plumbed?
    Part 2: is it that you think you have mustard algae based on the stain? It usually favors shady walls...
    Is your cya at 80 deliberately, eg for a SWG? Or if you're manually dosing, are you aware to maintain according to the FC/CYA Chart -- Determning whether or not you really have algae (SLAM if you do) and getting your other parameters inline would be the first priority, then followed by the acid wash tool.
    If you're not SWG, a partial drain and refill would als be good to reduce your cya level and make a slam, if needed, easier
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
