Thread: CYA Levels over 100+, will this affect my FC test results?
    Aug 2016
    Frisco
    2
    Hi everyone, I'm glad to be part of the troublefreepool community as I just bought a house with a pool and learning how to maintain it. I have a Leslie Pool Deluxe Test Kit (not exactly sure which one it is) and tested the CYA level. Both the test kit and the strips I tested with gave very high CYA level readings, 100+ on the Taylor test kit and 300+ on the AquaChek strips. What is confusing is on the AquaChek, my FC is +20 but on the Leslie, it's around 1ppm. My pool looks crystal clear and I smell a little bit of CC but not a whole lot. I'm confused as to if I need to raise the FC or lower it. My question is, does high CYA affect the accuracy results of the FC tests?
    23k Gallon pool, outdoors, not salt water, and in-ground.
    38,237
    Re: CYA Levels over 100+, will this affect my FC test results?
    High CYA will not impact the FC using a good test kit.
    We do not trust strips, so who knows if the FC is really that high. But, if it was and if your other test is just the DPD chlorine test (not the recommended FAS-DPD test) then it can be bleached out at high FC levels and appear to be much lower than reality.
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Quote Originally Posted by anhQpham View Post
    Do you have the 'Deluxe OTO' (yellow label) kit:
    http://www.lesliespool.com/Taylor-Te...Kit/K-5820.htm
    Or do you have the 'Deluxe DPD' (pink label) kit:
    http://www.lesliespool.com/Taylor-Te...Kit/K-1004.htm
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Aug 2016
    Frisco
    2
    It's the DPD test kit, I'll try the FAS-DPD kit and see where that goes. My kit looks like the pink label one and it says DPD on it.
