Results 1 to 7 of 7
Thread: First post. This place rocks
    Aug 2016
    Las Vegas, NV
    21
    So I discovered TFP a few weeks back as I struggled with mustard algae that would not go away. With your help I boosted chlorine levels and now have a handle on it. I have also banned trichlor tabs and gone to bleach as my CYA is 150+. Here is where I am today. I am hoping you can advise on the next steps. I know a draining of water is in my future but will wait until off season. I have elevated readings on just about everything. Here are some figures derived from the Taylor K2006:
    TC 10
    FC 10
    CC 0
    so far so good....but there's more...
    PH 8 (need about 1/2 gallon acid per demand test from what I gather)
    TA 175-200 (in order to get 120, this would call for several times the amount of acid required to lower PH to 7.4)
    CYA 160 (using 50/50 pool/distilled I got a reading of about 80 twice)
    CH not tested (strips indicate this is also off the charts)
    I want to thank you for all the great advice I have already received here as a lurker. I just had to register and become an official part of TFP.
    OK. I have one last important question...........why do some refer to BBB method when speaking of TFP? Prior name? Looking forward to your responses. Thanks again!!
    triptyx's Avatar
    Apr 2016
    1,438
    Re: First post. This place rocks
    BBB was the precursor to TFP.
    With a CYA of 160, your FC is too low. If you don't have a salt water system, you need to boost FC to 19, minimum 12. Anything below 12, at any time, will allow a potential breakout of algae, and not allow for sanitized water.
    The pH test isn't reliable above FC 10, but at a reading of 8, I'd pull it down a bit.
    Please put your pool details in your signature asap. This will let us help you much better.
    Welcome!
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Aug 2016
    Las Vegas, NV
    21
    Signature added.
    16,000 gallon in-ground, plaster
    Jandy 460 Cartridge filter
    Pool Cleaner
    Taylor K-2006
    30,395
    Welcome to the forum.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP!
    More here on BBB, Pool School - What is TFPC?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Welcome!
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    216
    If you can, I would replace 70% of your water to get the CYA down to 50. It's much more manageable that way! Plus, you can then let your FC come down to the single digits safely so you can get a good pH reading.
    Getting the TA down is a function of lowering the pH but doesn't need to be addressed immediately. It may make your pH rise again but then lowering the pH again will drop it more.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
