Hello
Trying to determine if my compressor is shot. 3 wires go to compressor unit ( wires with eyelets connections screwed into housing ) On the red wire which I think is the Common wire the silver tab is broken off. That wire was burned and separated. I put a new connection on it but compressor is still not coming on. Could that silver tab be replaced ? Kind of resembles a sofa can pull tab with a ring
I did try to use a multimeter ( first time using one ) and really don't know what I'm doing.
Changed both capacitors and fan runs just no heat and no error codes
Thanks
Thanks
