Results 1 to 16 of 16
Thread: Heat pump compressor
    Hello
    Trying to determine if my compressor is shot. 3 wires go to compressor unit ( wires with eyelets connections screwed into housing ) On the red wire which I think is the Common wire the silver tab is broken off. That wire was burned and separated. I put a new connection on it but compressor is still not coming on. Could that silver tab be replaced ? Kind of resembles a sofa can pull tab with a ring
    I did try to use a multimeter ( first time using one ) and really don't know what I'm doing.
    Changed both capacitors and fan runs just no heat and no error codes
    Thanks
    Tom
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Heat pump compressor
    Red should be 110v hot. Call your favorite HVAC guy to check it out.
    Yes, I'm not sure why I said common wire. It's 220 and is either the start or run wire. Just trying to find out if that silver tab can be replaced
    Tom
    DFW, TX
    24,485
    Yes, it can, but you need the right tools for the job.
    Ok thanks. Guess I'll spend the 200 to have it properly checked out
    Sent the HVAC guy that does pool heat pumps a picture of it and he says it's not repairable ��
    Tom
    DFW, TX
    24,485
    What is not repairable? The heat pump? The compressor? The wire?
    The compressor as its missing the silver tab on the red wire connection. That wire was corroded or burnt off. I replaced the wire eyelet but the silver ring to make contact on compressor is burnt off
    Want me to post a picture?
    Tom
    DFW, TX
    24,485
    Yes, that sort of thing, wires burning up, happens for a reason. The compressor needs to be replaced.
    I wish I knew the reason. Only 7 years old and even if compressor is covered under warranty they still want minimum of 1200.00 to install. Best to buy a new one
    Tom
    DFW, TX
    24,485
    Did you have it serviced every year or two by an HVAC company to maintain refrigerant levels and oil levels? That is usually what causes a compressor to fail.
    Honestly no and it never crossed my mind. Didn't know it had to be serviced for PM. Now I know. Thanks for the information although I wish someone at the pool company told me years ago
    Tom
    DFW, TX
    24,485
    You should be able to add it to your home AC service plan. It is basically the same as a home heat pump with a water exchange instead of an air exchange. The rest is the same.
    I don't have central AC. If I had maybe I would have known better
    Thank you anyway
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    353
    A lot of things can take out compressors outside. Lightning and related surges are just two of them. Catastrophic connector failure like that can result from either of those.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
