Thread: Sand Filter upgrade question.
    Jun 2016
    Panama City
    100
    I am thinking of upgrading a summer waves pool to a much bigger sand filter and pump. BUT, I want to locate the pump and filter approximately 70' from the pool. In this next pic the pump would be on the far side of the deck...Ideas? I want to run the piping under the deck above the ground then under the ground from deck to pool. If I go with a 1hp pump would it be able to handle the distance...I dont mind losing some pressure but would like to vacuum too! The skimmer is located about 30' from deck. Its hard to see, but I have a lean-to behind deck that pump would sit under.
    6500 gallon SummerWaves AGP. Taylor k-2006, Jacuzzi sand filter and two speed pump. City water. Third year in use!
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: Sand Filter upgrade question.
    I don't see a picture, based on what you described a 1 hp pump should be able to handle that.
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    Jun 2016
    Panama City
    100
    I'm not on WiFi, but I'll post pics in the morning once I get home!
