Thread: pH question
    Houston, TX
    1,102
    pH question
    For about 10 days, my pH stayed almost the same at 7.5. I usually have to add a little muratic acid to keep it out of the high 7's.
    Wanted to determine if any of the following conditions stabilizes the pH:
    1. We had about 7-8 days of straight rain, w a lot of clouds [vs the usual full day of sunl]. Also, the aeration of rain almost always increases pH
    2. Increased the Cyanuric Acid levels by 8PPM via 4 pucks over a 5-6 day period. I was low on Cyanuric acid bc of using TFP method and decided to get a bleach break by using pucks instead of the crystals in the sock/skimmer
    3. The cloudy weather also lowered the temperature by at least 8-10 degrees from hot to actually a pleasant coolness for the Aug time of year.
    4. Other?
    I keep my FC in the 4-5 range
    I am going to run a full set of tests tonight and will post these too.
    tstex
    InGround 15K gal, 18'x30' 3.5' to 5.5' depth w/ 9'x9' spillover Spa, Pebblesheen w/ Travertine, Hayward 3 HP VSP, Hayward C4030 Cartridge, Hayward 1.5 HP for 2 Scupper columns, ProLogic, PL-PS-8 Panel, Hayward H400FD 400K BTU Heater, 3 ColorLogic LED, Spa Blower, TF-100 w S-Stick, QC Tiger Shark, Autofill If you enjoyed your TFP experience, please consider donating to Support TFP!
    Jun 2010
    Glendale, CA
    513
    Re: pH question
    Trichlor is acidic. Mixed with the aeration and you found the sweet spot !
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Houston, TX
    1,102
    Re: pH question
    Thanks - Makes sense - Acid is acid...just wasn't sure how much the Cyanuric acid would impact the lowering or keep the pH steady.
    30,426
    Re: pH question
    What is your TA? Keeping TA down around 60 seems to stabilize pH somewhat. Borates do an even better job, apparently.
    Houston, TX
    1,102
    Re: pH question
    Thanks Dave...arrived hm real late last night...will do some testing this morning and post back - tstex
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,755
    Re: pH question
    Rain also helps because it is typically low in pH and has little to no alkalinity and no calcium.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
