Thread: Does water flow effect a SWG?
    Squeeken's Avatar
    Apr 2013
    San Diego, CA
    22
    Question Does water flow effect a SWG?
    I have a variable speed pump. I run my pump at 2500RPM for 2 hours/day and 1000RPM for 4 hours/day for a total of 6 hours. My question is this, does the SWG produce more chlorine at the higher water flow rates than it does at the lower water flow rates? Thanks.
    Pool: 18000 gal w/ spill over spa Pump: 3HP Intelliflo VS 011018 Booster: 1.5HP Sta-Rite Dyna-Max Filter: 300 sqft Sta-Rite System 3 Heater: Rheem RayPak 399 BTUH Chlorinator: AutoPilot Pool Pilot Digital Controller: Jandy iAquaLink RS PS8 PDA Cleaner: Pentair Pool Shark Plumbing: 2"
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Does water flow effect a SWG?
    No, the output is independent of the flow rate. You just need to be sure that the flow is sufficient to satisfy the flow switch on the SWG. 1000 rpm isn't quite enough for my system. I have to run at 1250 or more in order to generate chlorine.
    chiefwej
