Thread: Pump Basket Won't Fill Up (New Pool)
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    My water level got a little low and my Pentair VS Pump told me that it needed primed. I've filled the pool to a good level but the pump basket still isn't filling. I released the air from the filter. There is no valve at the main drain pipes. I have the skimmerclosed and the return open. Am I doing somethong wrong?
    18 x 38 gunite, 39-7 deep, 8 x 12 tanning ledge with 8 deep water, umbrella sleeve, 2 LED bubblers.
    2 Pentair LED lights, 16 long fiberglass hill slide and jump rock. Sand dune pavers/coping. TF-100. My build: Georgia Pool Build.... No Longer O/B :))
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Pump Basket Won't Fill Up (New Pool)
    with the hose in the basket I assume you are priming the pump with fill water first, then closing the lid and starting the pump?
    Dolphin E10 Cleaning Robot.
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Attempting that, but the pump never fills up.....it just keeping draining and staying 1/2-3/4 full.
    Hot6's Avatar
    Jun 2014
    Alabaster, AL
    27
    Quote Originally Posted by sheree202 View Post
    The most water you'll get in the pump is up to the bottom of the fill pipe. Then it starts filling the pool. Get it close to the white pipe seal it and turn on the pump.
    IG Vinyl 18x36 28500 Gallon SWG Taylor K2006 Test Kit
    380 Gallon Master Spa Chlorine for sanitizer
    sheree202's Avatar
    Jan 2016
    Lawrenceville, GA
    245
    Okay, that worked beautifully. I closed the filter air valve once it started shooting water. As soon as I opened the skimmer valve the pump got air bubbles in it.
    Hot6's Avatar
    Jun 2014
    Alabaster, AL
    27
    The air was probably in the skimmer line since you had the valve closed. Let it run for a bit and make sure it draws nothing but water. That's provided the fact that the pool water level is above the skimmer.
