Thread: FC loss after vacuum
    May 2009
    Charlotte, NC
    12
    Hi guys
    I am at the final push against algae. My chlorine usage each day has progressively dropped to about 30-40% a day at 50% CYA and almost have a zero Fc drop at night.
    One thing I noticed while testing in the last few days: Every time I vacuumed the floor, there is a slight increase in Cl usage, like 0.5 FC increase for about 2-3 hours.
    Is this due to
    1. algae growth during the day (no swimming yet), or
    2. Biofilm being disrupted, or
    3. Something in the filter or vacuum brush or
    4. Is Cl not as effective at 4' depth
    I have been vacuuming for a week, and so it is hard to believe there is still a biofilm. My Cl levels range from normal to shock ( about 8.5-14) during the day and (13 to 15) at night for a week. I also do have the pool turn somewhat less clear after vacuuming, that reverses in a few hours. My nos: FC 13, CC <0.5, PH 7.2, Alk: 100, CH 150, CYA 50.
    Thanks
    RV
    Above Ground 14.2 K Gallon, vinyl, Baquapure sand filter, 2.5 HP pump, K-2006 test kit
    Re: FC loss after vacuum
    Organic debris that falls to the bottom can get buried under subsequent layers of debris before chlorine has time to oxidize it. Vacuuming can expose the buried debris to the chlorine in the pool, which then uses up some of the chlorine.
