Results 1 to 7 of 7
Thread: Brand New Pool Owner - Small bubbles in filter return - Need help!
    Aug 2016
    Virginia Beach/VA
    16
    Good morning all! I have a 30,000 gallon salt water pool with a Hayward Pro Grid D.E. Filter.
    I noticed yesterday that there were small bursts of bubbles coming from the return jets in the side of the pool.
    I checked the baskets and emptied them. I also raised the water level to a little over half way up the filter baskets.
    At the pump, there does not appear to be any bubbles or air in the the water.
    I am not sure how to proceed from here.
    Any help is appreciated, and I am just getting started so my knowledge is very limited.
    Thanks in advance for any help!
    May 2013
    Massachusetts
    148
    Re: Brand New Pool Owner - Small bubbles in filter return - Need help!
    Are there bubbles in the clear pump basket viewer?
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    Sep 2009
    Houston, TX
    117
    Do you have a SWCG? What you describe is consistent with a Salt Water Chlorine Generator producing chlorine.
    15000 Gallons In ground, Ecobright pool finish, sand filter, Pentair intelliflo VS, SWG
    Aug 2016
    Virginia Beach/VA
    16
    I just checked, there is a slight bubbling (very small) at the very top of the basket.
    I am not sure (very new to this). I know I have a salt cell which makes the chlorine from the salt...
    May 2013
    Massachusetts
    148
    Welp, I Had slight bubbling too, both in returns and in pump basket. Plus the pump was continually losing prime overnight. I took a hose and ran it over each possible leak point on the suction side of the filter that was above ground. When I held my hose over the ball valve, the bubbling stopped. When I disassembled the joint, I found there was a kinked and degraded O ring in there. Replaced and pool pump runs good now.
    You can find out about how to use a hose to find a suction side leak on this site. Pretty handy.
    Hope this helps.
    DE, Hayward Filter
    Loud pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    A few bubbles in the basket is fine as long as it doesn't I crease and lose prime. SWGs often produce bubbles from 1 or 2 returns when they are producing chlorine.
    Aug 2016
    Virginia Beach/VA
    16
    It holds prime perfectly, and the bubbling at the basket is absolutely minuscule. The bubbling at the returns is very slight. When I youtube this, the videos I see are of massive amounts of air coming out of the returns. So it sounds like what I have is normal? I'll keep an eye on it for now.
    Thanks for the help!
