Results 1 to 8 of 8
Thread: Cloudy after brushing...Calcium on walls?
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    I have a fiberglass pool, and I can wipe my finger across the walls and get a slight white residue on my fingers.
    The day that I brush the walls, my pool is slightly cloudy the remainder of the day, but crystal clear all other days.
    Test numbers:
    8/23 - 0745
    FC 10.5
    CC 0.5
    TC 11
    pH 7.4
    TA 60
    CH 250
    CYA 50
    8/24 - 0800 (the day of brushing, but before it was brushed)
    FC 9.5
    CC 0.5
    TC 10
    pH 7.5
    TA 80 (I added baking soda yesterday afternoon)
    CH 250
    CYA 60
    I checked the CH AFTER brushing, vacuuming and cleaning the filter and I got 275, twice.
    Is this just the calcium depositing on the walls, and is it any issue to worry about?
    Kevin
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Cloudy after brushing...Calcium on walls?
    The test results here do indicate scale, but if PH is usually higher it could be scale. More here, Pool School - Calcium Scaling
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    I am getting a CSI of -0.09. The CSI in Pool Math says for all pools, greater than 0.06 is problem for all pools. Since "Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools."does not mention fiberglass, I am reading it as not a real concern at this time.
    TF-100 Testing Kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Can you check the baking soda you added (have been adding?) to see if it says "activated" or anything like that?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    I see no indication on the bag of "activated." It is Arm & Hammer, 5# bag bought at grocery.
    The issue is not new. It's been like that the 3 months I've been here.
    According to Pool Math, hovering over the CSI does read "balanced".
    TF-100 Testing Kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    The only other thing I can possibly think of is if the previous owner used dry acid to lower pH, I know that that adds sulfates and can weaken plaster. I know you are fiberglass, I assume it would be similar. I don't know how to test for sulfates, perhaps someone else will chime in.
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    Well, bottom line is that it's not bad, just noticeable.
    Tnx
    TF-100 Testing Kit
    DFW, TX
    24,485
    Quote Originally Posted by ka8yiu View Post
    That is correct, negative CSI has no impact on FG or vinyl pools. Anything below 0 is good for your pool.
