Results 1 to 8 of 8
Thread: 3" trichlor tabs in a pulsar 3 feeder???
    Aug 2016
    Nassau
    3
    Can I use regular old chlorine tablets in a pulsar 3 chlorine feeder. I know it's designed for calhypo brisquets but I live in a remote location and these brisquests just aren't readily avaiailable.
    Thanks in advance.
    Donldson's Avatar
    NW Ohio
    2,896
    Re: 3" trichlor tabs in a pulsar 3 feeder???
    Welcome to TFP!
    Never put the wrong kind of tablet in a feeder. If there has ever been cal-hypo sticks in the feeder then it is potentially dangerous to put trichlor tablets in it. Even if there hasn't been cal-hypo sticks the feeder will not provide enough flow to properly erode the trichlor tabs.
    If you need to replace the feeder you might consider other sources of chlorine that won't add calcium or CYA to your pool, such as a salt water chlorine generator or a liquid chlorine dosing system.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2016
    Nassau
    3
    Thank you for your prompt response. I'm aware of the pitfalls but as I mentioned before my location is remotelling and any change in system is difficult. I have a feeder and can easily get tablets. A different new feeder is just not possible.
    The pulsar system has been abandoned for a few years because of the unavailability of briquettes. I've tried to keep chlorine levels consistent but I just can't.
    The Pulsar 3 is rated to 250000 gallons so I don't see a problem with not enough chlorine flow.
    If I get in there and make sure the unit is properly cleaned can I make it work somehow. I'd really appreciate your feedback. Thanks again.
    Donldson's Avatar
    NW Ohio
    2,896
    Do. Not. Put. Trichlor. In. A. Cal-hypo. Feeder.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Isolated Spa - 345 Gallons
    30,421
    geneas,
    It sounds like you are going to do it anyway. Curious why you asked if it was OK?
    Aug 2016
    Nassau
    3
    Is there such a thing as a trichlor feeder?
    Can one use calhypo granular in the feeder?
    Donldson's Avatar
    NW Ohio
    2,896
    Nearly all chlorine feeders are designed for use with trichlor unless they specify otherwise.
    You will likely clog your feeder if you try using granules in it.
