Results 1 to 8 of 8
Thread: Pool wall and floor issues
    Aug 2016
    palmetto ga
    5
    Hello
    I have been told that I need to shovel dirt up against the outside wall of my pool (about 2'). is this true?
    Our pool was installed about 2 months ago and it has formed a 3-4" deep crevice under the floor liner that extends approx. 20' down the length of the pool. Would this have anything to do with dirt up against the wall?
    16*32 Doughboy AGP partially buried on three sides with deck surround
    1.5 hp pump with Doughboy filter
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Pool wall and floor issues
    Hi, welcome to TFP! Could you post a picture of the problem? Did you install the pool yourselves? Was the ground leveled by digging down into firm soil or was the soil built up? Does rainwater runoff into the pool area?
    Love TFP? Become a
    TFP Supporter!
    Aug 2016
    palmetto ga
    5
    Thanks! Because the crevice is on the floor of the pool and underwater, it is not visible with a camera. It was professionally installed but we noticed the floor had indentations in it right after the install and called them back out to look at it. At that time, they offered to drain the pool and redo the liner. Because we are on a well, we decided to live with the indentations. The crevice did not appear until a month later.
    The pool was installed on top of packed sand that was there from a round pool we had taken down. They added more sand to that though. No water run off into pool. After it gets light, imwill take a pic of the wall / dirt build up - maybe that will help...
    Aug 2016
    palmetto ga
    5
    Aug 2016
    palmetto ga
    5
    This is the side that is buried. In the image below, the crevice starts about 3' from the ladder, 12" away from the left hand wall and running down the length of the pool.
    Aug 2016
    palmetto ga
    5
    It wont let me load the last pic I have exceeded my quota. The last picture shows the outside wall that does not have dirt piled against the wall. It is the 32' side that is not buried. So, do you think I need to drain the pool and ask the installer to fix the floor? Do i need dirt around the sides that are not buried?
    Thanks, Margie
    May 2012
    Montville NJ
    545
    There is no need to pile dirt around the outside of a pool. You should have proper drainage so water does not collect around your pool, or run under it, but there is no reason to pile dirt against the outside. Now, on the INSIDE, there should be a cove at the bottom under the liner, between the wall and floor, either made out of sand or pre-made foam cove. Your installer should have put that in.
    As for the crevice - what are we talking about here. How big and wide. I understand it to be running paralell to the wall on the left side of your ladder, facing the pool. It's hard to tell from your picture, but is the soil sloped away from the pool on that side. It could be due to water getting under the pool. You also said the put the pool over where an existing round pool was. How did the build up the ground to make it level. How thick was the layer of sand that they added. Water is heavy, and if things were not compacted, that could be your reason.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    30,421
    If you only have sand underneath, that is a poor substrate and it sounds like the water is undermining the pool and cutting a channel into the sand. You will need to divert the water somewhere else. The pics don't show the subject, right?
