Results 1 to 7 of 7
Thread: DE back into spa only
    Jun 2016
    Austin, TX
    334
    my clean pressure on my DE filter is 20 psi. When I turn it to spa mode it jumps to 27 psi and the spa gets cloudy and murky. It seems DE is getting back into the spa. I have no idea how old the grids are (they could be up to 9 years old) and when I cleaned them a couple weeks ago I didn't notice any tears but there must be. I can't think of any other reason why it would be doing that. Time to replace them?
    13k Gallon IG Pebble w/ attached Spa, AquaRite T-Cell-15 SWG, Hayward DE6020 Filter, Hayward 2 HP Pump, Hayward 400k Heater, TF-100 Kit, Pool Logger
    Jun 2016
    Austin, TX
    334
    Re: DE back into spa only
    Now that I think about it. Maybe I put to much DE in the filter. I don't know. I think there is DE coming out when I open the air relief valve at the top of the filter when water sprays off. I see de powder in my equipment when the water dries. Still maybe bad grids or what? I am a newbie to this stuff? I added around 11-12 scoops in my 60 ft filter.
    Also, who knows. Maybe it's going back into the pool also but I just can't see it cause it's bigger and it's much less. Hrmm
    Jun 2016
    Austin, TX
    334
    Any advice on this? Should I just take the whole thing apart again or backwash to remove some DE or what? Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,484
    I am not very familiar with DE filters. Usually when they put DE into the pool is because of a small tear in the grid. Sometimes people find it when they open the filter because there is a clean spot on a grid.
    This might help too, Use and care for DE filters
    Jun 2016
    Austin, TX
    334
    I am thinking I put in too much DE. My filter needs 7.5 lbs. I put in 12 scoops thinking after reading something on INYO pools. I read on here that each scoop is about .75 lb or higher if you pack it which would leave me with 9 lbs of DE in there. Could that cause the DE to come out of the air release valve and also back into the spa?
    Jul 2015
    San Marcos, CA
    110
    I think the only way for DE to get into the return lines is thru a breach in either the filter elements or internal plumbing.
    If you have a VS pump you could run at a lower RPM (lower pressure) for longer. Much more energy efficient too.
    16 x 32 IG plaster pool, 23k gallons, built 1992, DE filter, Pentair VS pump, IoThyngs controller, Taylor 2006 test kit, SoCal water restrictions
    Newbies with green pools, see SLAM and Recommended Test Kits. My company: IoThyngs
    Jun 2016
    Austin, TX
    334
    Quote Originally Posted by Amail View Post
    OK i guess i need to pull the filter apart again. Bummer. I do not have a VS pump either.
