Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: First Time Question (Can I Never Run My Pump)
    Aug 2016
    Portland, OR
    9
    Hello Pool Experts,
    I'm new to Trouble Free Pool and to owning a pool.
    I bought a home in February in Oregon and am using the BBB method.
    I have read that you must run your pump 8 hour a day, but instead I manually vacuum 2-3 times a week. I also shock the pool with 1 gallon of Bleach a week. This is all I do.
    My Question is if it's ok to never run the pool pump, is there any reason to leave the pump running if my tests are all in range and the pool is blue?
    Thanks everyone in advance!
    Inground 23K gallon pool with vinyl liner, 30ft x 15ft
    Hayward Pump &
    Hayward Cartridge Filter
    Hayward Pump &
    30,426
    Re: First Time Question (Can I Never Run My Pump)
    Yeah, every pool gets dirty and you need to filter out the dirt and debris. The pump is the most effective way to do that.
    The way we suggest calculating run time is through practical observation. Run it 8 hours daily and if your pool is very clean, cut it back to 6 hours. Keep cutting it back until the pool starts to look dirty then bump it back up a notch.
    Personally, I would not suggest ANYBODY run their pools less than 4 hours daily. You need circulation and you need filtering in every single pool.
    On top of that, vacuuming and brushing as needed will keep your pool pristine.
    PS - Do you ever test your water??
    Aug 2016
    Portland, OR
    9
    Hey Duraleigh,
    Thanks so much for your help. I understand that you need to run the pool pump with filter, but why if the pool testing is perfect?
    Here are the readings:
    Total Hardness: 250
    Total Chlorine: 3
    Free Chlorine: 3
    pH: 7.2
    Total Alkalinity: 120
    Stabilizer: 100
    I'm just confused on the "why" if the water is blue and the tests are perfect.
    Here has been my routine..
    Vac 2-3 times a week.
    Shock 1 time a week with 1 gallon of liquid bleach. Leave Pump on for 2 hours.
    Thats it. I don't do anything more and the water has been perfect along with testing, the pH comes down mid week to about 6.8 then back up to 7.2-7.4 after the bleach is added.
    Hayward Pump &
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    For some they get so much tree debris falling, they have to run the pump longer to keep the surface skimmed and clean.
    Also if you have a salt water chlorine generator then you MUST run the pump long enough for it's daily dose of chlorine to be made.
    Do you cover your pool?
    I use a bubble cover on mine every day of the week, but might take it off after work for a swim. on saturday/sunday I take it off
    early in the morning.
    It stays clean running the pump only 2 hours per day during the week but on weekends I run it 4-6 hours to keep the surface free
    of debris & filter the water more. I also vac on saturday morning and might do it during the week if there is buildup on the floor.
    My water is crystal clear. But I do test with a TF100 at least every other day in the summer.
    It's kind of amazing that you have not had an algae problem with CYA (stabilizer) of 100 (could be over 100 when it tests at 100 btw) and FC of 3.
    But maybe those test results are not accurate. How are you testing? Pool stores are usually way off.
    Dolphin E10 Cleaning Robot.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,520
    So... you throw in a gallon of bleach a week. Is that too little or too much? How do you know? What is your CYA level? If you can't answer these questions then your not really using the BBB method.
    Edit.. I'm a slooow typer so I just now saw your test results. With a CYA of 100 your FC is less than half of what it should be. Maybe algae just does not grow that far north..
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I just had my pump go out for a month. I had no problems maintaining perfect chemistry, I used the kids to mix it all up. I made a thread about it in The Deep End. I'm used to the water clarity that comes with a DE filter and after a month had tons of tiny floating debris that couldn't get vacumned out. After I got the pump replaced I had to clean my filter three times, not from debris that you could see in daylight, stuff only visible at nightime. I see no reason you can't limit your pump run time to what you've specified it's just all about your tolerance for tiny debris.
    Also there is no reason to shock unless you are not maintaining your chlorine at the appropriate levels.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    30,426
    I'll try it one more time. There is no test for dirt. Is it your intent to let whatever debris falls into your pool to remain there?
    If you really question the functions of a pump, shut it off for a few months and tell us how that works out. I don't mean to be snarky but I am having trouble understanding what you are thinking.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    With CYA at 100 that is the top range of the test and it could be much higher. Do the diluted test to check, Pool School - Extended Test Kit Directions
    May 2016
    Toronto
    130
    Why would you not run a pump? If you have a working pump and a 23k inground pool, I really dont understand lol.
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    38,354
    Those test results are far from perfect. Your FC is dangerously low due to your high CYA.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I think this isn't really a question....it feels like trolling
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    222
    Absolutely no way throwing a gallon in once a week and vacuuming a couple times can be "all you do"
    Your free chlorine would be at zero within 2 days, unlikely it would survive the next 5 with zero chlorine. With cya at 100 that gallon only gets you half way to your minimum off 7 ppm. Shock level would be 29 ppm so you are not even getting close to "shocking" your pool.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    domct203's Avatar
    Jun 2015
    CT
    3,592
    Quote Originally Posted by Defgufman View Post
    +1
    Sure seems like trolling....
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2015
    N Tonawanda, NY
    475
    Just sounds to me that they're trying to save on their electric bill. If they're really just adding chlorine once a week it's going to cost them when they have an algae outbreak & have to add gallons of chlorine & run the filter 24 hrs.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    Eustis, Florida
    68
    A gallon of bleach wouldn't last a day in that pool. Something seems off.
    AGP 33' x 54" Lomart Verona, Approx. 27,300 gallons, Pentair cartridge filter/pump 2-speed, 1.5 hp, Dolphin Escape robotic cleaner.
    domct203's Avatar
    Jun 2015
    CT
    3,592
    Quote Originally Posted by chipchip View Post
    Agreed. It's seems quite improbable that the pool has been operated on one gallon of chlorine per week for the last 6 months.
    Even the test results seem more like "pool $tore recommended" levels, and are far from TFP 'perfect'.
    Dom - TFP Guide
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Your method certainly isn't the BBB method. Seems like a disaster waiting to happen!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Aug 2016
    Portland, OR
    9
    Hello Everyone,
    Thanks so much for taking the time to help with my question. As a brand new pool owner it's nice to get the help. For you thinking I'm trolling here, let me be clear I'M 100% REAL AND NEED HELP.
    So It seems like running the pump just for an hour or two once a week is ok, as long as everything is in range. I check the pool once a week and everything is in perfect range.
    Could it be possible that by NOT running my pump and filter it makes the liquid chlorine last longer? The "Unfiltered Pool" asks as a UV ray blocker from the sun? Just trying to find out why this method is working for me and everyone else runs it 8 hours a day.
    Hayward Pump &
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,216
    A couple of questions:
    How are you getting your perfect numbers? Do you have a test kit, or is the pool store testing them for you?
    If you don't run the pump, what is your method for getting rid of leaves, dead bugs, dust, pollen, etc.?
    Also, can you post a few photos of your pool, showing the bottom, steps, etc.?
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
  20. Back To Top    #20
    30,426
    What help do you need?
