Thread: Pentair IC60 cell only if I have Pentair Automation panel already?
    Nov 2015
    Lakewood Ranch, FL
    36
    Hi all,
    My solar installer offered to throw in a Pentair SWG install if I ordered solar heating from him. All I have to do is order the unit in advance of his install.
    2 questions:
    1) any recommendations on the cheapest place to order the Pentair IC60?
    2) Do I need the pentair SWG power center if I already have a Pentair automation unit, or can I just buy the Salt cell replacement?
    Thanks in advance!
    14,900 Gal free-form PebbleTec/Gunnite pool/spa, built July 2015, city water, caged
    Pentair Automation Panel, Intelliflo Pump, Clean&Clear Filter, MasterTemp Gas Heater, Intellibrite 5G Lighting, ScreenLogic2, IC40 SWG
    Paramount Clean O3, In-Floor cleaning system / Solar Heating panels
    TF100 test kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,460
    Re: Pentair IC60 cell only if I have Pentair Automation panel already?
    Johnny,
    If your panel did not come with a SWG, chances are it does not have the internal SWG power supply. Pretty easy to tell.. open the enclosure and look behind the bottom panel. If there are two transformers on the right side, one big one and one small one, then you have the power supply. If all you have is one small transformer, then you do not have the internal PS.
    Try SunPlay, they always seem to have pretty good deals.
    Nov 2015
    Lakewood Ranch, FL
    36
    Thanks Jim!
    Here's my panel... There is only one small transformer inside but there is one outside the panel to the right. Not sure what is for, in-floor cleaning maybe?
    Would this work or should I order the power center too?
    Quote Originally Posted by Jimrahbe View Post
    Johnny,
    TF100 test kit
    Jul 2014
    Bedford, TX
    7,460
    Johnny,
    That is a 12 volt transformer and I "assume" it is for your pool lights or some landscape lighting. I suggest you follow the output wires and see what relay they go to, and what that relay is supposed to control.
    I also noticed something that I did not realize.. on the front panel is a number of small circuit breakers in the upper right hand corner.. The one for the SWG/Intellichlor is missing. I had assumed it was there, just not connected. Also, the missing SWG transformer is about the same size as the one in your sub-box, but I'm pretty sure it has more than a 12 volt secondary output..
    Nov 2015
    Lakewood Ranch, FL
    36
    Thanks again Jim, looks like I'm going to have to spring for the power center.
    TF100 test kit
