Thread: baja step and bubbler
    We had a PB that introduce an idea about installing a bubbler on the baja step. However we are choosing a different PB that had a better overall design. How would you install the bubbler. Is it like a spa jet installed on the floor of the baja step?
    How deep is the baja step is it like a deep 1st step? 12"?
    This is what Im talking about.
    should be great for the kids.
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: baja step and bubbler
    is this for your spa or pool? If installed in the pool, I would arm yourself with some muratic acid, as I would imagine the aeration such a water feature would provide would promote frequent PH rise.
    Central Florida
    84
    Quote Originally Posted by dmanb2b
    Never heard this, we have 3 on our step and have to put acid in the pool once to twice a week. PB used these for our 3 bubblers on baja step in the pool.
    Only thing I would have liked is that the baja step be 10-12 deep instead of the 6-7 inches.
    18k free form IG w/spa (4 jets), Paramount in floor cleaning system, Starite system 3 filter, Jandy 2hp ePump, Sta-Rite SR400LP Maxi-therm propane heater, Jandy aquapure/apurem 1400 SWCG, Jandy automation PS4 w/PDA, IntelliBrite 120v 5-G LED pool & spa lights, 2" piping and (3)4x12 (5)4x10 Fafco Sunsaver Solar Panels.
    Can you give me more detail on this part? Trying to lock down the spec for new pool with PB. thanks
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    yup...aeration increases PH without affecting TA. I would venture to guess your ta reading are probably low or you have to also use alkalinty increaser (Baking soda)...since adding MA lowers PH and TA
    Quote Originally Posted by towney
