Thread: Cloudy water
    elainerader's Avatar
    Apr 2013
    Columbia, MS and Blue Ridge, GA
    120
    Cloudy water
    It's been raining A LOT, have had to increase chlorine levels to keep the pool blue during that time. I am keeping the chlorine at my normal 4 now.
    pH is 7.2
    CL 4
    but the water is cloudy......tried to find a thread about this but couldn't readily locate one.
    Will boarating the water clear this up? Never have used borates to this point, but wondered if that was the problem.
    Thanks
    25K GALLON IG VINYL
    LASER SAND FILTER, Hayward SP2610X15 Super Pump 1.5 HP Pool Pump
    UNDER WATER LIGHT
    14 YEARS OLD, LINER 5 YRS OLD
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Cloudy water
    No, borates won't help. Extra FC and extra pump time will clear it. FC level is set based on CYA level and the FC/CYA Chart. It needs to be above minimum at all times to keep the pool sanitary and algae free. Raise FC up to 50% of shock level to help clear it up. If you suspect some algae or bacteria growing in the pool you can perform the Overnight Chlorine Loss Test to check.
    Apr 2013
    120
    Re: Cloudy water
    Thanks for clearing (no pun intended) that up!
    I just raised the level again to 1/2 of shock, which, based on my CYA of 20 I have been keeping it at all this time, at 4
    I will run the filter longer as I have been only running it 2 hours a day, and see if that helps. Thanks!
    25K GALLON IG VINYL
    UNDER WATER LIGHT
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: Cloudy water
    Two hours is definitely not enough run time to keep to the water clear.
    You should run the pump at least 4 hours a day to keep the water clear. Pool School - Determine Pump Run Time
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
