Results 1 to 12 of 12
Thread: IC40 v. IC60
    Jul 2016
    Las Vegas
    325
    IC40 v. IC60
    I am getting ready for my first time salt pool. The specs for the size of the pool clearly fall into an IC40. So why do people recommend the IC60 rather than the IC40? Is bigger just better?. Does it make a difference if one is running at 80% and the other 60%, as long as the outcome is the same? is there a power difference, or?
    My pool is 16x34. 3.5 - 5 - 4 deep... with a 6.5 foot wet deck and a couple steps... so not sure of the volume yet, but clearly less than 18K.
    I do not understand these things yet, so maybe my questions are dumb, but hey ...lol
    thank you.
    Cement Pond <--- build - 15K gal, 16 x 34 Rectangle, All Pentair - 520 Filter, 2 Intelliflo 2VST pumps (3hp) - 1 filter/1 water features, EasyTouch 8, Screen Logic, IC60 SWG,
    Pop-up Cleaners (Wet Deck and steps), 2 LED Bubblers, 3 LED 24" waterfalls, 5G LED Pool Light, Quartscapes Reflections Tahoe Blue plaster, Real Coral coping/deck, TF-100 Test Kit, 1766 Salt test kit.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: IC40 v. IC60
    Shorter pump run time and longer cell life.
    The specs for the cells are based off a 24 hour runtime. Who wants to do that?
    Go for the ET8 IC 60 combo ($1800) and ScreenLogic($375).
    Don't screw around with the IC40. The abovementioned setup can actually be had for less money than piecing everything together and that includes the actuators.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Re: IC40 v. IC60
    An IC60 produces more chlorine than an IC40 in the same amount of time. So the theory is that you can run the IC60 at a lower percentage or for less hours per day, which should mean the cell will last longer.
    I did a rough calculation the other day and because the IC60 costs more, it appears to be a wash to me, cost wise.
    I have about the same size pool as yours and my IC40 works for me. If you can get a deal on the IC60, I'd do that, but I would not make it a project killer, as the IC40 will work just fine.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: IC40 v. IC60
    I agree with Jim. You'd be fine with the 40 but the value is in buying the complete setup. If the 60 fails years down the road, you could throw the 40 in.
    Pentair EasyTouch 8SC-IC40 Pool and Spa Control with IC40 Cell
    Looks like the ET8 is offered with the IC40. You'll have to run the numbers to if the cost difference is worth it....I always get the biggest of everything but that has more to do with a compensation issue.
    -Brian-
    POOL BUILD
    Jul 2016
    Las Vegas
    325
    Re: IC40 v. IC60
    Quote Originally Posted by bdavis466 View Post
    I have the combo with the IC40... but IC40 is still in the box (spacer is in place), and can exchange it and pay the difference I would think... But from what you guys are saying.. I should stick with the IC40
    I had gotten the EasyTouch 4, but just swapped boards and have the 8 now.. and I have the screenlogic2
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: IC40 v. IC60
    You'll be fine with the 40.
    When you switched boards did you get the relays too?
    -Brian-
    POOL BUILD
    Jul 2016
    Las Vegas
    325
    Re: IC40 v. IC60
    No, I didn't realize I needed them until the electrician said he needed them... so, I'll them up when I grab my tile. Any suggestions on that? Was going to get 4.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: IC40 v. IC60
    Amazon.com: Pentair 520106 Relay Assembly Replacement Pool and Spa Control Systems, 3 HP: Patio, Lawn Garden
    Not sure if there is better pricing but thats the relay for the ETs. Ask the electrician how many he needs. There really isn't a need to buy extras unless you are planning on something else in the future.
    -Brian-
    POOL BUILD
    Jul 2016
    Las Vegas
    325
    Re: IC40 v. IC60
    Nice! I ordered three... he said he needed two if I wanted equipment light on it. figured I would get one more for yard lights in future.
    May 2015
    Land O Lakes, FL
    527
    Re: IC40 v. IC60
    Personally, I would go with the 60. You will be able to run your pump less. This will translate to using less electricity for the pump and SWG.
    The link in my signature to the SWG Calculator will enable you to enter the amount of Chlorine generated for each and see the result for your size pool in regard to the SWG output % and average daily FC loss.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: IC40 v. IC60
    Quote Originally Posted by mgmoore7 View Post
    -Brian-
    POOL BUILD
    Jul 2016
    Las Vegas
    325
    Re: IC40 v. IC60
    I called the supplier... its done, the IC60 is on hold for me. They will exchange the IC40.. perfecto.
