- May 23, 2015
- 24,381
- Plaster
- Pentair Intellichlor IC-60
The pool is swimmable now so I would just turn on the SWG at 50% and run the pumps at 12hrs/day and see what happens. If the FC stabilizes or increases slowly, you can shave off pump runtime.
Also, play with your speed settings on the VSP to see when the flow switch cuts off on the SWG. You should not be running the pump at full RPMs, it's a waste.
