Thread: Timing of vermiculite and liner?
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    How soon after vermiculite is done can liner be installed? Immediately or does it need to "cure"?
    IG Vinyl Mountain Pond 22x36/ Depth: 3'4"-6'6"/ About 19,000 Gallons/ Pentair/ Clean&Clear Plus420/ Intellichlor IC40/
    Easy Touch/ Intellabrite 5G LED Color-Changing Light/ DeckJetsII/ S.R.Smith slide
    Crickets's Avatar
    Apr 2016
    Lexington, ky
    119
    Re: Timing of vermiculite and liner?
    Any ideas?
    Jul 2016
    Holly Springs, NC
    85
    My PB said they lay the base in the shallow end the day before the liner to allow it to harden so they can walk on it the next day when they finish the base on the slope and in the deep end. They then put the liner in.
    43x31x20 lagoon shape, vinyl, inground pool. Approx 27,000 gallons. 3.5' to 5.5' depth. Latham natural gray liner, Pentair Tagelus fiberglass sand filter, Pentair Intelliflo pump, auto SWG, 3 LED intellibrite lights. Construction beginning Aug 11, 2016. K-2006C test kit.
    Apr 2013
    Sacramento, CA
    2,769
    A day works. Two at most. Its a concrete product but it never really gets that strong so its better to get the liner on and water in to protect it.
