Thread: Index Sand Filter Problem
    When my intex sand filter is running it gets all the air out of the system, but when I turn it off, a bunch of air comes from somewhere and fills up half of the area with the clear lid and leaf basket. What could be causing this? The intake and output are both underwater and there are no leaks in any of the connections.
    Intex 15X48 metal frame pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Index Sand Filter Problem
    Is your filter or pump mounted at above pool water level?
    Quote Originally Posted by Isaac-1 View Post
    No, it is below on the ground.
    30,431
    The pump can be pulling in air from the suction side. The air then compresses in the top of the filter and, when you shut off the pump, the compressed air pushes back and some of it stays in the top of the pump basket.
    I think you have a loose fitting or something that is allowing air into your suction side. I can think of no other explanation.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,550
    The most common place for it to leak is the o-ring around the clear plastic lid on the prefilter basket. Make sure it's not pinched and the lid is screwed on tightly.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    domct203's Avatar
    Jun 2015
    CT
    3,596
    Quote Originally Posted by jeffchap View Post
    +1
    Also, a little silicone or teflon based o-ring lube can really make a difference. I use Jack's 327 on all O-rings and eyeballs.
    https://www.amazon.com/Hayward-SPX03.../dp/B00CG4GMTG
    Any brand is fine, just make sure it is NOT petroleum based lube.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
