Thread: Little "Pimples" Behind Liner
    Jul 2015
    Fort Blackmore, VA
    23
    I was in my above ground pool the other day and I notices little bumps almost like pimples all around the pool wall behind the liner. The pool is an Esther Williams pool and is 12-13 years old. I know it could be a sign of wall corrosion, but this liner is less than a year old, so I was able to look the wall over good before putting it in last year and there were no signs of rust or any type of corrosion. It looked like it was in great shape as far as I could tell. Any ideas on what it could be?
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Little "Pimples" Behind Liner
    They mostly corrode were leaks acure, like at the skimmer, returns, wall seam, or around the base. If its all round, I have no clue.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2015
    Fort Blackmore, VA
    23
    Quote Originally Posted by banditig View Post
    Yep all around the pool. They are about halfway up the wall and go all the way around.
    Jul 2015
    Fort Blackmore, VA
    23
    BUMP
    Jun 2013
    Augusta, GA
    90
    I have the same issue in a newer pool, and I don't think it is due to corrosion. I believe it is dirt and sand that is trapped between the pool wall and the liner. Or that's the lie I tell myself to feel better, lol.
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
    Jul 2015
    Fort Blackmore, VA
    23
    Quote Originally Posted by tommyd123 View Post
    I guess it's possible that sand got up on the wall when we installed the new liner. Glad to see someone with a newer pool has the same thing going on.
