Results 1 to 9 of 9
Thread: Easytouch questions related to IntelliChlor (IC60)
    Jul 2016
    Austin, TX
    348
    I'm putting together my wish list for a system for a new pool build. I'm leaning towards a Pentair pump and Pentair SWG. This will be for a pool and spa likely around 16,000 gallons. From what I have seen on Pentair's site they have a bundle that includes Easytouch 8 w/ "SCG integration" + IC60 cell and 2 actuators. I read the "SCG integration" to mean they have a built in transformer in the panel that negates having to use the external transformer. I really only need the Easytouch 4 and personally would rather use Jandy actuators, so I'm looking at starting with the base Easytouch 4 and adding on. So 2 questions:
    1) Does the base Easytouch 4 panel include a transformer or is this only in the "SC" (bundled) versions?
    2) There is a single body (Easytouch 4P) and pool/spa (Easytouch 4) version. The "4" includes 2 actuators. I would prefer to use Jandy actuators. I believe there are other differences than just the included actuators. Can someone confirm that for a pool/spa combo that I need to purchase the "4" version?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: Easytouch questions related to IntelliChlor (IC60)
    I don't believe the ET 4 is bundled with the IC60, only the 40. Jandy actuators will work with the ET if that's what you want to use but there is nothing wrong with the CVA24s from Pentair. I have 5 of them and haven't had any issues.
    If you break down each items price in the ET8 w/IC60 you'll see that it really is the best bang for the buck.
    With an ET4, you will only have 3 relays since the 4th is used to run the pump, SWG and heater. I would much rather have 4 unused relays in my panel than wish I had one just more.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Foos,
    No matter how you buy it, I'd also recommend the ET8 instead of the 4. I have the ET4 and have already had to kluge in another relay. Once you have automation, you will keep finding things you want to add. As Brian already pointed out, the ET4 really only has three unused relays. Most people use another relay for the pool light and that assumes you only have one light. If you have multiple colored lights and you want to be able to independently change the lights color, you'll need one relay for each independent light. In my case my pad light is controlled by the ET, as is my Pool Landscape lighting, and my water fill valve takes another one.
    You can buy the ET4 and ET8 with and without SWGs and actuators, but I think the cheapest version, in the long run, includes both.
    Since you have a Pool and Spa, make sure that you buy the "Dual Bodies" Version and not the "Single Body" Version".. Some ET's have the internal SWG power supply and some don't, so make sure you buy the ET with the internal PS.
    Dec 2014
    Riverside California
    482
    +1 on the Easy Touch 8. You will always find more things you want to add, hence more relays required. Also, be sure to add ScreenLogic to any Easy Touch system you install. Almost required IMHO.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Jul 2016
    Austin, TX
    348
    Thanks for the feedback! I ran the numbers and as bdavis466 points out the ET 8 with I60 bundle is the best bang for the buck (seems like a no brainer now). Also, good input on the CVA24, I will plan to use these. I also didn't realize 4 was so limiting, so I like the headroom. I am definitely adding Screen Logic and have no plans to add a remote...everything will be controlled thru iphone / ipad. I just got really excited as I saw Pentair is working on Amazon Echo integration: Alexa "Turn on Spa".
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Quote Originally Posted by Foosman View Post
    What was the attraction to the Jandy actuators?
    I think I would rather be in the spa with Alexa but in my world, it would just be another female that doesn't listen to me.
    -Brian-
    POOL BUILD
    Jul 2016
    Austin, TX
    348
    Quote Originally Posted by bdavis466 View Post
    LOL. When meeting with pool builders they want the wife to be there...one told me the other day, 99% of the time the wife and husband disagree and 99% of the time the wife wins. On the valves, I read an opinion from one guy (looks like it's a 3 year old blog):
    "The Pentair Valve actuators (the device that turns the valves automatically form say Pool to Spa) are sub par. . The gears and motor were redesigned a few years ago and they are constantly not turning correctly. I would recommend any other brand Valve Actuator over the Pentair one. Jandy Valve Actuators are the best. But the automated system itself is easy to operate and reliable."
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Who was it that said that?
    You'll have a 3 year warranty on all of your equipment anyway. If one fails after that you can replace it with whatever you choose.
    That's the first one heard of that issue with the CVAs
    -Brian-
    POOL BUILD
    Jul 2016
    Austin, TX
    348
    Here is the source, he seems to be a Pentair fan except for the actuators:
    http://poolmandave.blogspot.com/2013...t-pentair.html
    I totally agree, I will run the CVA24's into the ground...they aren't a high dollar item like a pump/etc.
