- Jan 4, 2016
- 5,289
- Plaster
You can use any of the vials. And once you try the speed stir you will realize why you invested in it...trust me
You can use any vial you want with the speed stir. Why do you think your FC values are approximate? You need precise values especially when doing an OCLT.
Back yaself, mate. I trust your CH number over the pool store any day.
You can turn off your SWG and let the FC drift down. You want to have a target FC of 5 and you don't want your FC to get to 3 as that too close to FC of 2 which will allow algae to grow. I try to keep my FC a little above target so that it can handle my lab getting into out of the pool 100s of times a day bringing in his muddy paws and dirty toys. So, you might want to kick the SWG back on when you get to 6 or 7 so have a buffer while you determine your run time and %.
Most of us keep our run time and % at the same level throughout the week and dump in bleach if we have a large bather load like on the weekends as SWG are good at maintaining, but bad at increasing FC.
You'll need to get a handle on your TA as higher TA makes PH rise faster. Having a SWG and a spill over will also increase your PH faster. Some of us keep our TAs around 50, but you'll have to figure out which TA level will help to keep your PH from rising too fast. Read this article about lower TA: Pool School - Lower Total Alkalinity
The wiping of the tip for that test is to discharge the static electricity. It helps keep the drops consistent.
+1 to a minimum of 4 ppm FC for CYA at 70 ppm.
I know the chart says 3, but considering the likelihood of error in the CYA test and that the actual calculation wold be 3.2 anyway (using minimum of 4.5% of CYA from Chem Geek's footnote), 3.5 or 4 is a safer minimum.
This great question is why I suggest keeping a log of all of your tests results. I have a small notebook I keep mine in. After a while you will notice a pattern. I even note "weather"-cloudy, rainy, windy, VERY hot, etc.
"Normal" daily loss of FC is 2-5 ppm. Like you noted it depends. The log will help you really learn your pool and it's needs.
