Thread: What I learned here in a few weeks
    Aug 2016
    New Haven CT
    62
    Hopefully this will help other newbies like me. I bought a new house with a pool in the back and had no idea what I was getting into. The owners ran through "Pool School" with me in about 30 minutes, shooting from the hip!
    Within a week my pool was getting cloudy and turning green. I found this forum and the help provided turned it around in 4 days to a clear blue pool. I just like looking at it if that makes sense.
    Before I found this site I stopped at the pool store, bought a kit that didn't test everything, and later had a water sample tested.
    Now nearly 3 weeks later I reread the store report and see what I didn't at the time.
    CYA was measured at 90
    FC = 3ppm
    I has no idea this ratio was way off but the report was all "good" with only phosphates high at 400. Once I got the Tf100 kit I was able see the CYA and Fc levels and with info on this site found I needed a lot more chlorine at that CYA level. But by the time I figured this out the pool was green!
    I'm sure no expert by any means buy I do understand the chemistry now and the water shows it. I have kept the FC level within the range on the table listed here using the extra shock I bought. A little goes a long way now. I have the CYA down to 50-55 and FC about 7
    Gary
    New Haven, CT
    16 x 32 x 8 in-ground vinyl , sand filter
    22,000 gallons
    Leslie test kit, TF100 test kit
    30,421
    Re: What I learned here in a few weeks
    That's a great post, Gary.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Nice work, thanks for the feedback!
